New Slab On Top Of Existing Slab??? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-04-2017, 09:43 AM   #1
Rewards Points: 6
new slab on top of existing slab???
Hi
I am converting attached open garage to enclosed garage
I am excavating perimeter for the foundation
question is
in order to avoid demolishing the existing concrete slab, Can I put the excaveted diert over the existing slab
than 6" sand than,
plastic sheet following,
some crashed rocks / gravels finaly,
rebars / wire mesh
Thank you
Toros is offline   Reply With Quote
Old 03-04-2017, 09:58 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,512
Re: new slab on top of existing slab???
If compacted properly you should be fine.
I would skip the sand and just use compacted gravel.
Old 03-04-2017, 12:27 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,780
Ayuh,.... How much are you raisin' the existin' slab, to the new slab grade,..??
Generally speakin', dirt don't make a good sub-base,...
Old 03-14-2017, 02:48 PM   #4
Flannel Guy DIY
Flannel Guy DIY's Avatar
Rewards Points: 224
drill holes, put short rebar in there sticking upwards. Then, repour
Flannel Guy DIY is offline   Reply With Quote
Need to raise carport slab 10" to match house slab for room addition manfredswinkle Flooring 4 04-18-2015 09:27 AM
Room addition on existing cement slab and roof Cossack Building & Construction 6 06-20-2012 10:39 PM
Pouring new concrete around existing slab on grade. Supercontinent Concrete, Stone & Masonry 1 06-19-2012 12:20 PM
Strand Bamboo on existing Engineered on Slab? jdavemb Flooring 0 12-17-2011 08:51 PM
Building on existing concrete slab JimSpokane Building & Construction 2 07-22-2009 02:19 PM
