(new Pics) Exposed Wood At Bottom Of Vinyl Siding, How To Weather Protect - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2015, 08:21 AM   #16
Food Truck & Old House
Rewards Points: 332
There is a stone foundation, at the front near the corner I dug down a good foot and there is my field stone foundation there
Is there a best way to protect it from the winter? Would it be wrong to silicone the aluminum flashing to whatever that "concrete" wall is underneath the newer vinyl siding?
Should there be any openning at the bottom? Say I dig a trench along side the hole another 6" deep and fill it with small stones, should there be any air gap from the flashing to the stones? Or should the flashing sit in the stones at all?
Would vapour barrier be beneficial at all here? I have some 6mm thick stuff that I bought for laying in the crawlspace
KevinEF7 is offline   Reply With Quote
Old 10-23-2015, 11:27 AM   #17
Rewards Points: 1,336
All wood portions of the structure should be at least 8" above the grade. This will allow 8" of masonry/fieldstone to be exposed to any water splash. The wood should then be covered with a suitable siding material. The flashing you spoke of could be used as long as it will drain the water away from the wood portions. Do not seal the bottom as any water that may get in there would need a way out
danpik is offline   Reply With Quote
Old 10-23-2015, 12:09 PM   #18
Rewards Points: 332
I was thinking of putting the flashing vertical, up and down the same direction the siding is going, do you mean it should bend 90* under aswell?
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
What do I put on exposed wood until siding is put up? Michelle D Building & Construction 8 07-17-2010 10:38 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Vinyl siding over wood clapboard C&D Building & Construction 3 09-13-2006 10:14 PM
