Need Moulding To Stop Water From Spilling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-03-2015, 03:42 PM
Rewards Points: 1,120
Need moulding to stop water from spilling
Hi;
Our kitchen counter is flat, with absolutely no moulding around the outside to prevent water from dripping from counter to floor. This is especially bad at the sink. Any amount of water that is splashed onto the counter in front of the sink (there is only about 3" counter between the sink and the edge) drips over the edge to the floor, and gets onto the person who is at the sink.
There should have been some sort of "berm" around the whole counter. Now I would like to add this. Something I can buy in a roll would be OK. I can use contact cement to attach it.
Can anyone point me in the right direction? I don't even know what to call such a product.
I don't care whether it matches the counter top or not. White is fine.
FW
Ultrarunner2017 is offline
Old 07-03-2015, 04:26 PM
Rewards Points: 5,348
I have never encountered such a material or a customer who had the problem. I would suggest less flamboyance with the dishwashing and maybe a towel draped over the counter in those areas you are having the issue.
Ron
B. Franklin 1759
Ron6519 is offline
The Following User Says Thank You to Ron6519 For This Useful Post:
joecaption (07-03-2015)
Old 07-03-2015, 04:32 PM
Here is a photo of the countertop and sink.
Note that there is no slope to the countertop. It is perfectly flat.
Also, the water that splashed out of the sink is not coming from a faucet that is turned on too strong. It gets splashed out during normal process of washing dishes - especially large trays.
Old 07-03-2015, 04:38 PM
The problem is when washing large trays (like baking trays and large casserole pans), the sink is too small, and the dish needs to be lifted and turned this way and that to get it clean.
This problem occurs when anyone washes dishes, so its not one person's technique.
I'm thinking of buying a roll of some sort of rubber or plastic moulding and gluing it to the edge of the countertop - to create a berm. I would also like to place such a berm on the left side of the sink, so that water doesn't run onto adjacent counter space.
I also think that some of the water comes off the dish drainer tray if the edge does not protrude over the sink lip. It gets pushed back sometimes. Another berm behind it might help - or a better drainer tray that might stay where you place it.
I think that the real problem is the sink's size - it's too small - and the countertop size - also too small - not enough counter space between the edge of the sink and the edge of the counter.
What about a rubber mat that would go around the sink, with a lip in front. Perhaps I can fabricate one from something else.
Old 07-03-2015, 04:44 PM
Rewards Points: 1,042
Sounds like you just need a larger sink.
Canarywood1 is offline
The Following User Says Thank You to Canarywood1 For This Useful Post:
Old 07-03-2015, 04:51 PM
The simplest and easiest thing would be a neat bead of clear caulk at the very edge of the counter.
Ron
B. Franklin 1759
Ron6519 is offline
Old 07-03-2015, 06:31 PM
Rewards Points: 2,526
If an absorbing towel won't do the job the bath tub comes to mind or take the pots and pans to the car wash.
SeniorSitizen is offline
Old 07-04-2015, 11:02 AM
I can try that - my only concern is mildew. It might be difficult to clean the caulk. Maybe if I get the mildew resistant variety?
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 02:37 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
Water Tight Laundry Room (prevent water from spilling over into other rooms) asummit Remodeling 6 03-29-2011 06:17 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
