Need Help Removing Mirror In Bathroom - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-25-2015, 04:27 PM   #1
Rewards Points: 323
Need help removing mirror in bathroom
I'm trying to remove a mirror in downstairs bathroom that has four corner tabs. The stupid home builder probably has the mirror glue or caulk down to the wall. It's stuck so what can I do aside from smashing it to pieces to take it off?
johnv713 is offline   Reply With Quote
Old 06-25-2015, 04:35 PM   #2
craig11152's Avatar
Rewards Points: 1,220
what do mean by 4 corner tabs?
My guess is its just stuck from years of sitting. I would remove one, maybe both top corner tabs, and with gloves, long sleeve shirt and safety glasses take a pry bar and try to gently work behind it. it will either come loose or crack.
You could throw a bunch of duct tape on the mirror to help control the break if thats what happens.
craig11152 is offline   Reply With Quote
Old 06-25-2015, 04:40 PM   #3
Rewards Points: 3,576
With safety precautions in mind, try a length pf dental floss to cut the glue bond.
Old 06-25-2015, 05:02 PM   #4
Rewards Points: 323
I'm assuming they used a lot of adhesive because I've tried everything and the mirror hardly moves. Dental floss will break I'm sure.
Pry bar is too thick to insert between glass and the wall. The duct tape is a great idea.
Old 06-25-2015, 05:54 PM   #5
I'm sure if you haven't tried sawing with dental floss you won't know so get the duck tape and pry bar.
Old 06-25-2015, 07:19 PM   #6
Retired Moderator
Rewards Points: 7,174
The glue will tear off the paper face of the drywall---try this--wear long sleeves and gloves--
Get a hand full of wood shims---slip one behind the mirror and lightly tap it in place --add more shims--tap them tight---do this slowly and the paper will give up---the mirror guys usually use two suction cup grips and just pull--
We remove a lot of mirrors---only had one or two break---be careful---
craig11152 (06-26-2015)
Old 06-26-2015, 02:49 AM   #7
Rewards Points: 323
I think the person that puts up the mirror used a boatload of glue, probably spreads the adhesive the entire back of the mirror.
Old 06-26-2015, 06:05 AM   #8
Retired Moderator
Try prying it off--if it breaks--then plan on replacing the drywall after you smack the mirror and remove it in peices--
Old 06-26-2015, 07:26 AM   #9
craig11152's Avatar
I like the shim idea. No matter what wear eye protection.
The Following User Says Thank You to craig11152 For This Useful Post:
oh'mike (06-26-2015)
Old 06-26-2015, 07:33 AM   #10
Retired Moderator
My assistant had one big one break and slash the sleeve of his sweat shirt---
He now has a greater rspect for the potential danger.--Be careful.
Old 06-26-2015, 01:38 PM   #11
Rewards Points: 323
long sleeve and goggle it is. Thanks! Here's to a big smashing
removing window from bathroom ryan.l Remodeling 2 12-10-2012 02:48 PM
Removing master half bath to extend main bath ryanb4614 Plumbing 18 08-27-2011 08:21 AM
Need help removing Delta bathroom faucet Mr_allthumbs Plumbing 6 06-01-2010 05:50 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
Removing Towel Rack to paint bathroom bigbearok Painting 3 02-12-2009 06:40 PM
