Need Chimney Demolished Nd Rebuilt Or Not?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 05-13-2019, 04:02 PM   #1
Rewards Points: 194
Wink
Need Chimney Demolished nd Rebuilt or Not??
How to know if a chimney needs to be demolished and rebuilt or just repaired???
I noticed that one of my chimneys was a little tilted and so I contacted a company. They came by when I wasn't home and left an estimate for both chimneys stating that both need to be demolished and rebuilt to the tune of close to $20,000!
What do I know and how can one ever tell?
I know this question is vague but, after getting ripped off many times for other house repairs, I'm just a little skeptic that both chimneys really need to be demolished and rebuilt.
So any help will help
Jacke is offline   Reply With Quote
Old 05-13-2019, 04:21 PM   #2
retired framer
Rewards Points: 4,614
Re: Need Chimney Demolished nd Rebuilt or Not??
Post picture of them and the problems you are seeing, there are people here that know this stuff.
Jacke likes this.
Do not use flat bottom gables with scissor trusses.
The Following User Says Thank You to Nealtw For This Useful Post:
Jacke (05-15-2019)
Old 05-14-2019, 07:35 AM   #3
Rewards Points: 492
Also how do you use the chimney? How tall is the house?
Wood burning fire place? Gas burning? Or only to vent boiler/furnace, water heater? If the chimney is tilting, how much?
Replacing the whole chimney, why? Is it on the side of the house, or does it go through the house?
No doubt that estimate is for complete replacement, starting at the footing (is it tilting at the footing?), and best masons will not be cheap (insurance, liability, running the office), including setting up the work site for demolition and rebuild.
For bit of perspective.
Jacke likes this.
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Jacke (05-15-2019)
Old 05-15-2019, 11:42 AM   #4
Rewards Points: 194
[QUOTE=Nealtw;5832319]Post picture of them and the problems you are seeing, there are people here that know this stuff.[/QUOTE
Old 05-15-2019, 11:48 AM   #5
Rewards Points: 194
Aded pictures to my album-only way I could figure out how to add the pics.
Nealtw likes this.
Old 05-15-2019, 11:51 AM   #6
retired framer
from there you can copy and paste.
Just below here you can go advanced and manage attachments.
Old 05-15-2019, 05:18 PM   #7
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,928
Ayuh,..... Are both chimneys in use, or obsolete,..??
SPS-1 likes this.
Old 05-15-2019, 07:24 PM   #8
Rewards Points: 8,990
.....and how can one ever tell?
Is that am optical illusion, or are both chimneys leaning ? (actually, one looks bent like a banana)
I am no mason, but don't think you can "adjust" that.
SPS-1 is online now   Reply With Quote
Old 05-15-2019, 09:40 PM   #9
Msradell's Avatar
Rewards Points: 952
Especially the one on the side of the house which is significantly leaning definitely needs to have at least the part above the roof line replaced. The other windows look so bad but certainly hard to tell from the distance the photos are taken from. What do they look like below the roof line? Quite possibly do anything you need to do is have him rebuilt from the roof up which shouldn't be terribly expensive.
Some close-up pictures would certainly give us more to work from.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-15-2019, 09:47 PM   #10
retired framer
Could they not be replaced with a 0 clearance steel and just wrapped with wood a bunch cheaper.
Old 05-16-2019, 12:21 AM   #11
Rewards Points: 923
Really need to have these inspected close up. Can't tell from pictures if the mortar is solid on them. I had a chimney that looked fine from the ground but when you got on the roof you could rock it back and forth about 1/4". I ended up rebuilding the part above the roof line.
I assume these have always been "bent" like this? Meaning they were constructed by someone who was afraid of using a level and straight edge?
chiraldude is offline   Reply With Quote
Old 05-16-2019, 12:24 AM   #12
Rewards Points: 923
If the structure below the roofline is solid, it would be cheaper to rebuild just the part above.
Nealtw likes this.
Old 05-16-2019, 08:41 AM   #13
Rewards Points: 194
Never use the fireplace chimney but could. But... will never use it.
The other-furnace chimney. I assume it's in use.
PS - Sorry...am a single, older female who doesn't know too much about these things.
Old 05-16-2019, 09:24 AM   #14
Rewards Points: 692
Get a couple of more estimates.
I have a chimney like the one on the end of your house. Mine tilted away from the house and not toward it as yours does. The mason I used said that tilting over time is not uncommon if the chimney isn't tied into the house with metal straps as it is built. My chimney tilt was corrected by tearing down the top 4 feet and rebuilding (added ties this time).....cost me $3000 about 10 years ago. As other have said the pictures don't show the condition of the mortar joints and bricks.
Again, get more estimates.
$20K might be reasonable for a complete rebuild.....but the question is whether or not that amount of work is necessary.
JIMMIEM is offline   Reply With Quote
Old 05-16-2019, 09:39 AM   #15
retired framer
This is what you hope for to have a chimney removed.
The furnace chimney can be replaced with pipe like this instead of a new chimney
New furnaces vent out the side wall with plastic pipe.
Same with the fireplace, if it has to come down, then I would look at a system that uses a similar metal pipe and have a wood box built around it.
Jacke likes this.
Jacke (05-17-2019)
Leak from chimney exiting below grade Lemkie HVAC 4 07-15-2016 12:38 AM
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 11:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
