Nailing Roof Sheathing N Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-16-2015, 08:10 PM   #1
Nailing Roof Sheathing n Tiles
A friend has asked me to come over to Sweden to fix/replace her roof. Normally in the UK using 4 x 8 boards the most you're going to do is nail every 8" but in Sweden they use 100mm x 20mm tongue and groove. I'm thinking as the planks interlock do I really need to put 2 nails in each plank per roof truss? That would be a lot of nails and work especially as they recommend 100mm nails which seems a bit long to me,( in the forest off grid so no nail guns). Plus all those nails might split the wood.
Going to use cement tiles which I've never worked with. How easy/difficult is it to bash the nails in right to the end without cracking the tile? The local chain DIY seems to only do untreated tongue and groove and untreated batons of the size recommended by the tile manufacturer.
Advice appreciated
petrg is offline   Reply With Quote
Old 11-16-2015, 08:32 PM   #2
Rewards Points: 18,384
99 percent of the people on this site are in the US an have no clue when it come to metric measurements or how roofing is done over sea's.
Old 11-16-2015, 08:58 PM   #3
Hi, Thanks for that- hadn't realized this was US forum. 100mm is about 4 inches 20 mm 3/4 inch
Old 11-16-2015, 09:01 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 224
The cement tile is not the waterproofing. You need a membrane on wood decking.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 11-16-2015, 09:10 PM   #5
Metric is so much easier and we should have changed over to it at least 30 years ago.
No phenumatic nail guns in that area?
Old 11-17-2015, 04:32 AM   #6
I know, I have researched everything, read the manufacturer's requirements and watched loads of Youtube videos so much so that I can tell when someone is doing it the wrong way.
But I've not seen people nail cement tiles. I like to plan everything so there are no surprises or mistakes as this is a serious job
Old 11-17-2015, 04:38 AM   #7
Never having used one not sure how good they are
I will check and see if there is a hire shop. I thought about the battery/cartridge type but I can't take it on the flight out there or back so if I bought one there I'd have to leave it behind
Re metric, I think you do use metric in the engineering and science field as it's universal the world over. In the UK we use both as the general public are so used to feet and inches
Old 11-17-2015, 05:45 AM   #8
Rewards Points: 6,652
Actually if Shumaker Scott is still active (have not been on his project thread for "German House Rebuild". He is the most knowledgeable expert in this area. Of course with all of the information and pictures he has posted. You do not even have to look no further. If anyone has been able to show people how to do things outside of the box. Scott is the best one that has shown us.
Old 11-17-2015, 05:48 AM   #9
Here is everything you need to know about your original question. The guy that rebuilt the house has put his heart and soul into it. He is retired Army and decided to stay in Germany after he got out. It does take a bit of time to go through, since you get caught up in reading about the details of his home build. http://www.diychatroom.com/f49/germa...rebuild-23424/
Old 11-17-2015, 06:16 PM   #10
Wow that's an awesome rebuild! I notice he didn't stagger the roof boards
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Tile Roof - To offset or not to offset tiles kowtow Roofing/Siding 3 12-07-2010 11:17 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Placing roof sheathing vertically Clutchcargo Building & Construction 5 08-26-2007 11:21 PM
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 02:02 AM
