Mystery Leak - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2015, 08:36 PM   #1
Rewards Points: 1,090
Mystery leak
Does anyone have any ideas what this might be? There is a brown fluid leaking onto the dryer in the basement this is a one floor house and its more or less under a wall between the kitchen and bathroom. Smells like a campfire. It's the apparent drip from the floor above is not near any drain, the kitchen sink is 5 feet away in one direction, the toilet 3 feet in the opposite direction.
Best guess is possibly a roof leak, haven't been able to get into the attic yet. While observing I could not see any of you dripping from running the very this fixed years but after everything I've stopped running I did feel 1 drip I cleaned the top of the dryer and in the last half hour there's been a few drops on a paper towel I left there.
I'm just a lay person doing DIY as a loner. Eliminating K&T, L&P and sagging structure one room at a time.
WillK is offline   Reply With Quote
Old 01-03-2015, 09:51 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 23,968
Do the drains go into the wall? Start by filling the sink and then let drain. See what happens downstairs.
Old 01-04-2015, 08:26 AM   #3
Just the bathroom sink. Tried that but it didn't cause any increased leak or drip in the basement. The sink drain would go to the stack in the same wall, it's over the kitchen joist cavity next to the one with the leak.
Old 01-04-2015, 08:45 AM   #4
Rewards Points: 107
Could easily be a roof leak. By the time water runs down through a wall it will be brown even if it's rain water. Dishwasher above? Could be a leak there.
jimn01 is offline   Reply With Quote
Old 01-04-2015, 07:56 PM   #5
Doozer
Rewards Points: 237
Creosote smells like a campfire and comes from chimneys. Do you burn wood? If so, is the chimney anywhere on the same side of the roof ridge as the leak? Leaks can move quite a ways horizontally before the drip down into the living space.
FatBear is offline   Reply With Quote
Old 01-05-2015, 07:07 PM   #6
Rewards Points: 4,480
Open a small hole in the wall and check it out.?
ron45 is offline   Reply With Quote
The Following User Says Thank You to ron45 For This Useful Post:
Windows on Wash (01-06-2015)
Old 01-06-2015, 07:49 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,126
Start cutting open inspection if you can't check the roof.
Old 01-07-2015, 10:11 AM   #8
Update, the dryer onto which the leak was dripping had been cleaned and paper towels left to watch for more drips. The leak moved. I took the front cover off the dishwasher and saw a drip from the supply line. Haven't been back to the house since to see if the problem is fixed.
Intermittent Toilet Mystery Leak bills_diy Plumbing 6 04-07-2018 09:20 PM
Mystery Leak Running Out Of Ideas... miamicuse Roofing/Siding 30 08-15-2013 08:47 PM
Mystery - leak or no leak turness Plumbing 4 01-12-2013 07:46 PM
Mystery Basement Leak vanishingson Building & Construction 18 12-30-2011 10:00 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
