Moving The Washer/Dryer - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-08-2015, 01:13 PM   #1
Rewards Points: 2
Moving the Washer/Dryer
I know this may be difficult to answer without seeing what I am working with, but I am desperate for help. We have a raised ranch home and the laundry room is downstairs in the middle of the finished basement. The ceilings are drywall, not the drop tiles. I am moving the laundry room to an over-sized closet in the mud room. Surprisingly, the mud room is almost directly below where the dryer vent currently runs. The dryer is gas, and the home is old so it is not on a flexible gas line. The closet in the mud room has two breaker boxes. Is there anything to worry about with moving a washer and dryer to this closet with the breaker boxes. I am guessing the dryer will be more efficient with the move because it cuts 15 feet out of the vent, but I am nervous about running the gas line (and cutting into a wall with so much electrical behind it) plus is their an additional fire hazard risk? Any feedback would be appreciated.
wfhjob1 is offline   Reply With Quote
Old 03-08-2015, 02:34 PM   #2
Rewards Points: 3,130
Please put your location in your profile. Codes vary, and that will help with advice specific to where you live. The first issue, common in many places (in the US anyway), is that there are some things DIY homeowners can't legally do like plumbing, electric, or gas work. Permits and inspections would also be involved. Only your local building/permit department (or what here is often called the "AHJ" or "Authority Having Jurisdiction") can tell you what is required for what you want to do.
That aside, it doesn't seem like a difficult or complex job, especially if you plan to tie into the existing dryer vent. I've actually done something like this in one of my houses, except my dryer was electric.
Old 03-08-2015, 03:16 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
one thing to pay attention to:
the breaker boxes are required to have 3 feet clear space in front of them (nothing at all within that space, not even another breaker box) a minimum of 30 inches or the width of the box, whichever is less. If there are two (typically standard) boxes they will be 20" wide each. The 30" required by each box can overlap so if they are immediately side to side that would give you a 40" space which is acceptable.
the clear space must go from the floor to the ceiling.
Old 03-08-2015, 09:41 PM   #4
Msradell's Avatar
Rewards Points: 982
It looks like the two previous posters have just about covered the major issues you will run into. The code requirements for clear space in front of the breaker panels will probably be the biggest problem to achieve with what you're proposing. Doing the electrical work since it's just 120 V shouldn't be a major problem and probably won't require a permit many places. The water and drain lines probably fall into the same category. The gas line however is a bigger issue and quite possibly could require a permit.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 03-09-2015, 04:15 AM   #5
Rewards Points: 5,012
What ever you decide to do, get a pro to handle the gas.
Lesson learned...
I installed a gas water heater it was probably about the 35th one, and it didn't want to light. The directions was right there and I read them three or more times thinking I was doing something wrong. I mean how hard could it be, and each time I waited longer then the recommended time between trying to light it.
To make a long story short. There was very bright flash and I jumped back. I didn't feel any pain but my hand and fingers where a light charcoal grey. it burned all the hair off my arm and the side of my head. The flesh on my hand and fingers was toast, it cracked, peeled , and bleed, it took a long time to heal.
These things happen all too often, even to the well seasoned and pros.
https://www.google.com/search?q=home...UQsAQ#imgdii=_
ron45 is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 02:39 PM
Moving our Washer/Dryer INSIDE the house! javapop Plumbing 6 09-19-2014 06:11 PM
Adding a washer/dryer to existing washer/dryer setup oper573 Plumbing 1 01-30-2011 10:48 AM
Moving washer/dryer, etc. ClnlBrahm Plumbing 17 12-29-2010 09:47 PM
Moving washer/dryer from basement to 2nd floor DIY newbie Appliances 3 02-14-2010 08:38 AM
