Mounting Tv Above Mantel With Mirror - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By 007noob
  • 1 Post By ddawg16
  • 1 Post By ron45
  • 1 Post By Nealtw
Old 11-23-2018, 09:07 AM   #1
Rewards Points: 92
Mounting tv above mantel with mirror
Hi
If this is possible I need some how-to ideas on mounting the tv above the fireplace. That big mirror is getting the way. Please see the pictures.
I was thinking on installing a “decorative lumber” going across the top of the door (on the left) to above the above the window (on the right). Then mount the tv to that lumber and maybe rest the bottom of the tv without the stand on the mantel.
Would be nice if I can mount the tv above the fireplace and be able to move it vertically up and down as well. But that may be out of the picture in this setup.
Anyways looking ideas and suggestions.
Thanks.
007noob is offline   Reply With Quote
Old 11-23-2018, 09:21 AM   #2
Rewards Points: 8,304
Re: Mounting tv above mantel with mirror
When mounted above a fireplace, a TV is typically too high to start with, so I don't see needing to move it up and down.
If you don't want to remove the mirror, just put something in front of it to black it out, and put the TV on the mantle.
SPS-1 is online now   Reply With Quote
Old 11-23-2018, 09:25 AM   #3
retired framer
Rewards Points: 490
Is the mirror on an angle to the mantle.
Nealtw is offline   Reply With Quote
Old 11-23-2018, 09:28 AM   #4
Rewards Points: 92
Mirror is not at an angle. It goes straight up to the (2nd floor) ceiling - that is the ceiling is about 17 foot high.
Nealtw likes this.
Old 11-23-2018, 09:36 AM   #5
retired framer
Rewards Points: 490
Something like the center section in this picture might work.
Old 11-23-2018, 10:07 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 9,786
I think you need to find a better location for the TV.
Or....
Get rid of the mirror.
If you use the fireplace, a tv above it is a poor idea for 2 reasons....the heat from the fireplace 'could' damage the TV...and the light from the fireplace distracts from the image on the TV
dd57chevy likes this.
Old 11-23-2018, 11:08 AM   #7
Rewards Points: 180
After the work, you may find the advices about the angle and the heat were right after all. I'd put the tv on the mantle first (have someone hold it there) and test if it works, at least angle wise. Lean on the mantle first and make sure it feels like it can support the tv temp.
Work: Door and the window on the sides have frame behind the trim and the drywall. Frame may be 1" or bit more inwards from the jamb edges. Small drill bit would be the test to find the frame center. You may want to remove little bit of drywall to visually make sure. You could remove those trims, screw in blocks that are proud of the mirror, screw in a 2x6 or 8 on the blocks. You'll have to dress the rough lumber or find finished lumber. Possible to make the cross frame with plywood. Then return the trims. One thing about the door side is the block will prevent the door from opening further. Your door opening will be limited to the opening minus the door/hinge. Also install a door stop so it never bangs into the tv frame.
carpdad is offline   Reply With Quote
Old 11-23-2018, 05:25 PM   #8
Rewards Points: 4,634
Totally love that mirror.
I'm pretty sure the mirror weighs more then the TV.
I would set the TV on a mount that attaches to the mantel
https://www.harborfreight.com/catalo...Cf&q=tv+mounts
or
https://www.harborfreight.com/17-in-...-tv-64238.html
Don't forget your 20% off and free gift coupons
ron45 is online now   Reply With Quote
Old 11-23-2018, 05:31 PM   #9
If you are in doubt just use two of these or something like 'em.
https://www.architecturaldepot.com/BKTWHA.html
Nealtw likes this.
Old 11-23-2018, 07:54 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 94
Personal tastes, but I'm not a fan of the mirror (too big) or mounting TVs above fireplaces (too high). If you were to put it on or above the mantle, I would use a proper mount rather than trying to balance it on a strip of wood. Remember that you have to get any cabling up there as well.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 11-23-2018, 08:13 PM   #11
retired framer
Rewards Points: 490
Suction cup
https://gostikproducts.com/model-gotv1/
jbfan likes this.
Old 11-24-2018, 12:29 AM   #12
Rewards Points: 180
I like the suction cup idea, although I was thinking you can't depend on it. I never bought expensive suction cups. Since the shelf looks sturdy enough, you can use the cup and fix the tv to a safety cable? Drill holes in the attach plate for the cables.
Old 11-24-2018, 12:36 AM   #13
retired framer
Rewards Points: 490
We had the idea that we could hoist a 500 pound window up with a come-a-long and one suction cut. Cup never moved but the glass broke.
Old 11-25-2018, 09:48 AM   #14
I would definitely use the braces
You can also use raceways painted or not to hide or cover any wires
There's lots of ways of doing it, pick the one that you like.
https://www.google.com/search?q=race...w=1920&bih=938
You can even use the TV's stand and put a few screws in it to secure it to the mantel.
I would LOVE any all input on mounting my mantel!! bigdonniebrasco Concrete, Stone & Masonry 9 10-04-2015 10:50 PM
Mounting A Mirror Robert Guercio Interior Decorating 6 10-15-2013 04:52 AM
Mounting Lighting Fixture onto Mirror ostinoh Kitchen & Bath Remodeling 5 02-01-2012 06:25 PM
Mounting a mirror on off-center studs? SteveB87 Remodeling 4 09-29-2011 08:42 PM
Please help with mounting a bathroom mirror RickDel Building & Construction 6 05-25-2009 08:06 PM
