Mounting Electrical Box To Basement Chimney Stack - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 11:34 AM   #1
Rewards Points: 20
Mounting electrical box to basement chimney stack
I wasn't sure if this should go in the electrical section or the HVAC section, so I just dropped it here in the general section.
This outlet box was screwed to a scrap piece of 2x4 and the 2x was then glued to the chimney stack. The adhesive eventually gave way and fell off the stack.
Can I use some short Tapcons to attach the box directly to the chimney? This stack is the vent for the hot water heater and the furnace. Any issues doing it that way? Dumb question, but should I be concerned about carbon monoxide getting in or anything like that?
Btw, ignore the cut copper pipe. It was for an old water softener that I removed.
Maynard is offline   Reply With Quote
Old 02-15-2014, 12:02 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,790
Ayuh,.... I'd just glue it back on, rather than takin' a chance of crackin' a block, myself,...
PL makes glues that'll hold it,...
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Basement Electrical and Lighting hebron1427 Electrical 11 07-09-2012 11:37 PM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement Waste Stack The Vintage Sou Plumbing 3 08-17-2010 02:47 PM
Finishing basement - electrical code ??? normwannabe Electrical 1 01-23-2006 08:48 PM
