Is Mold Easy To Get Rid Of? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-13-2015, 01:12 PM   #1
Rewards Points: 1,294
Is mold easy to get rid of?
My daughter has been house hunting for months. Today another came on the market and its the best neighborhood I've seen.
The house is "as is". Its going into foreclosure. I drove past today intending to walk around. Some old geezer came up to me and said he's "buying this house". He said I wouldn't want it cause it had a roof leak and theres mold in a wall.
If that guy was right, something must be able to be done or else why did he want to buy it?
What do you do if you suspect mold, who do you hire to verify it? Do you tear drywall out?
Startingover is offline   Reply With Quote
Old 03-13-2015, 01:19 PM   #2
ZZZZZ's Avatar
Rewards Points: 2,900
Do a search on the forums here. Lots of previous threads about dealing with mold.
In a nutshell, it all depends on how widespread the problem is. Small infestations can be dealt with by DIY, Remove/replace drywall, clean any framing. I have used this stuff very successfully. http://www.homedepot.com/p/Concrobiu...5326/100654126
Most importantly, you must first fix the source of the moisture.
Widespread problems should be dealt with by a pro.
ZZZZZ is online now   Reply With Quote
The Following User Says Thank You to ZZZZZ For This Useful Post:
Startingover (03-13-2015)
Old 03-13-2015, 01:23 PM   #3
ZTMAN's Avatar
Rewards Points: 384
In this situation, I would contact the listing broker and ask for a showing. If no big red flags, I would make an offer contingent on inspections etc.
Have the appropriate inspections
Identify and problems
Determine cost to correct problems
Make decision to proceed with purchase after the problems and cost to correct are identifed.
Sounds like the old geezer is trying to scare you away. Any issue can be corrected, but you need to get a licensed and reputable inspector and , if mold is identified, get a proper abatement professional involved for an estimate
ZTMAN is offline   Reply With Quote
The Following User Says Thank You to ZTMAN For This Useful Post:
Old 03-13-2015, 01:51 PM   #4
Ok, I'll do a search here, on mold, and read up.
The realtor should have suggestions on who to call to correct the mold if it needs a pro. Actually, since this is Florida mold must be a common problem so there should be plenty of pros around to fix the problems.
We'll check the stuff at Home Depot.
Old 03-13-2015, 06:04 PM   #5
Rewards Points: 6,236
My question is how does he know there is mold in a wall as really the only way to know what is in a wall is cut a hole. Just because there was a roof leak doesn't mean there is mold. If the roof was fixed in a timely manner there may be no mold at all.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
Old 03-13-2015, 09:56 PM   #6
The roof had mismatched shingles in large area. Every room had evidence of mold. House has been vacant several years at least. One bathroon (under bad shingles) the baseboard was so rotted it was almost disintegrated. The wood vanity was bowed out from moisture.
One pocket door had visable mold when I pulled it out.
This ceiling was the worst. There were many poorly patched areas thru out this 1,895 sf house.
Old 03-13-2015, 09:58 PM   #7
Old 03-13-2015, 10:39 PM   #8
The second photo is one of the rounded corners in the house. We can't figure out why it needed repaired or why it was repaired with what felt like a shingle or asphalt, unless thats the only material that would bend.
I don't know but am thinking too much work and money. I would hate to see the condition of the attic after seeing interior damage.
Its a real shame such a beautiful house was let go like this. The owner died in 2006 and the family let it get like this. At the height of the market, 2004, it was valued over 200K.
Old 03-13-2015, 10:54 PM   #9
ZTMAN's Avatar
Rewards Points: 384
Good decision to walk away.
Old 03-16-2015, 03:29 PM   #10
Rewards Points: 56
an interesting thread
langit is offline   Reply With Quote
Need help with wall AC unit (mold and dirty) h22lude HVAC 6 03-23-2015 05:43 PM
Hello All, little help with basement mold problem? :) markaj311 General DIY Discussions 18 02-14-2013 05:27 PM
MOLD found on Wood Subfloor under Fridge-HELP!!! krissyp19 Building & Construction 37 01-11-2013 12:08 PM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 08:03 AM
Mold growth in basement under shower. Need suggestions to fix leak and clean up mold vseven Plumbing 6 12-10-2009 03:33 PM
