Memory Foam Bedding - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-06-2015, 04:49 AM   #1
Rewards Points: 112
Memory foam bedding
I was wondering about the memory foam bed we have. Can we put a piece of plywood to firm it up? Other than buying something new,are there other idea's?I am sure we have no option's,but I thought I would give it a go. Thanks.
sirweldalot is offline   Reply With Quote
Old 01-06-2015, 07:28 AM   #2
Rewards Points: 4,480
Nothing beats a try, but a failure.......
ron45 is offline   Reply With Quote
Old 01-06-2015, 08:53 AM   #3
Rewards Points: 6,652
If you kept the old box spring, yes you are supposed to place either Plywood or Chipboard between the box spring and mattress.
Old 01-06-2015, 10:02 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,476
Ayuh,..... I bought a brand new bed for here at the house, but at the river house, We just slipped a piece of 3/4" plywood in 'tween the box spring, 'n mattress,...
Summer mornin's went from an hour or so of back pain, to bein' "Refreshed" after a Great nights sleep,....
Bondo is online now   Reply With Quote
Old 01-06-2015, 08:19 PM   #5
Rewards Points: 996
are you saying you don't like the memory foam ?
Fix'n it is offline   Reply With Quote
Insulating in the attic with spray foam strategery Insulation 3 04-07-2013 11:46 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 12:42 PM
using XPS and spray foam together in stud bay diybrad Building & Construction 5 08-06-2011 08:08 PM
Synthetic Stucco over XPS foam techinstructor Building & Construction 6 07-12-2009 09:23 AM
Spray Foam/ Foam Board Hybrid? entropyracer Roofing/Siding 2 09-19-2008 07:12 PM
