Loose Ceramic Tile Repair? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-03-2017, 11:08 AM   #1
Rewards Points: 30
loose ceramic tile repair?
Hey guys,
I've been having this issue for a while now, and it's gotten to the point I may want to do something about it. Basically, I have a single tile that keeps making a "clunking" sound every time I step on it, and over the months, I have noticed the grout around it loosening. none of the other tiles exhibit this "clunk", so i think it's just local to this one. I think that when the contractors placed this tile on, that the floor beneath it was not completely even, and so anytime you put pressure on the tile, it shifts. However, it does not "move", if that makes any sense. Maybe it just moves so minutely, that it affects the grout. Is there anyway to repair something like this easily, without having to tear apart all the tiles around it? what do you guys recommend. Please see below for the area that is affected. thanks.loose ceramic tile repair?-b1.jpg
ilumo is offline   Reply With Quote
Old 05-03-2017, 12:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 6,706
Re: loose ceramic tile repair?
Get out your grout saw and cut it loose.
Clean the floor and tile and apply the proper thickness of thinset to rebond the tile.
Re grout once fully cured.
Old 05-03-2017, 01:51 PM   #3
Rewards Points: 4,330
And then hope this is truly isolated to this tile and not an insufficient structure problem....
stick\shift is offline   Reply With Quote
Old 05-03-2017, 02:30 PM   #4
Rewards Points: 2,811
I think it might be tough to take the tile out without breaking it. And if you do get it out, it might be tough to clean the mortar off.
Drill some holes in the grout line surrounding the tile. Pump some stuff in there to fill the void. Hopefully you can find it. You can drill the middle of the tile too, but then the hole is harder to hide. There are some products made for this. You need something pretty thin to flow in there.
mathmonger is online now   Reply With Quote
Patching ceramic tile floor due to change in cabinet footprint Sparco41 Flooring 0 08-18-2012 10:22 AM
Tile Repair - Filling Void, Reusing Tile Jdubya57 Building & Construction 0 07-09-2012 12:21 PM
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 09:55 AM
Concrete floor prep for ceramic tile tpanc13 Flooring 39 06-22-2010 09:50 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
