Looking For Help - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-10-2015, 04:52 PM   #1
Rewards Points: 8
Looking for help
Ok, I saw a product a while back that I thought was very cool.
It was a kind of block that had a v shape in the bottom and a grove sticking out in the top and the two fit togather with an epoxie sealant. It had 2x4 steal studs built in with built in foam insulation. It also had holes for threaded rod to go all the way to the top to pull it all togather and hold it. It said that it would withstand up to 160mph winds and walls could up to 60 ft. tall.
Anyone know what this is and where to find it?
Thanks for all your help.
mccartyser
mccartyser is offline   Reply With Quote
Old 08-10-2015, 06:19 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,444
What was it for? Retaining wall, footer, other?
Old 08-10-2015, 06:37 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
sounds like a mortar-less (dry stacked) building system. Can't say I have seen anything as complete of a system as described though. I did find one company designing a system using what looks like concrete Leggos though:
The Following User Says Thank You to nap For This Useful Post:
Windows on Wash (08-10-2015)
Old 08-10-2015, 11:57 PM   #4
Rewards Points: 8
Looking for help
No it was a complete system to build a house or a commercial building.
It said that you could put up a 2000 sq. ft. building in a day.
The blocks were almost like a tongue and grove kind of thing. No mortar just a epoxy. The threaded rod went from top to bottom and it pulled it down tight.
On the inside it already had metal studs and foam insulation, it said that you used a hot knife to make passages for wiring and such. Then you just put up drywall or whatever you want on the inside. Also they said that they could bring the machine to your site to make the blocks so the shipping wouldn`t be there.
Also they said that they could make and stamp the outside to look like whatever you want, Brick, stucco, castle shaped blocks. All kinds of neet stuff.
Again they said it was very strong and could withstand winds of at least 160mph. said it would be great for coast lines for storms and such.
Thanks for your help,
Have a great day
mccartyser
