Leaky & Cracked Pool - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-18-2015, 05:58 PM   #1
Rewards Points: 4
Leaky & cracked pool
I'm about to buy a house with a fiberglass pool that has tiny cracks in the rim around the top, and the tenant says the pool has a small leak. What am I getting myself into?
realitybend is offline   Reply With Quote
Old 06-18-2015, 07:38 PM   #2
Rewards Points: 50
A house with a built in money pit . With fiberglass pools there are two types of cracks, superficial and structural; the superficial cracks are simply cosmetic but structural cracks indicate a poorly constructed shell or installation, or the pool has been subject to physical damage. Most fiberglass cracks can be repaired, whether the repair will last or whether new cracks will spring up depends on what caused them in the first place. This is probably a case where hiring a pool company with experience in fiberglass shells would be worthwhile if you plan on keeping the pool operational as fiberglass is one of those materials that requires some experience to properly repair.
troyks is offline   Reply With Quote
The Following User Says Thank You to troyks For This Useful Post:
realitybend (06-19-2015)
Old 06-19-2015, 10:40 AM   #3
Rewards Points: 4
Thanks, troyks.
Old 06-21-2015, 09:13 AM   #4
Rewards Points: 14
Definitely agree with Troyks - get an expert in to come and look at the pool. You can never tell if it's going to be a serious problem in the future and cost you tons of money.
Marc7101 is offline   Reply With Quote
The Following User Says Thank You to Marc7101 For This Useful Post:
realitybend (06-22-2015)
Old 06-21-2015, 09:18 AM   #5
Rewards Points: 109
See if you can trace back the original supplier of the shell. My pool has a lifetime she'll warranty against cracks if installed by an approved installer. Not sure if it transfers to future owners or not but worth at least calling them to ask the question
Olcrazy1 is offline   Reply With Quote
The Following User Says Thank You to Olcrazy1 For This Useful Post:
Long run of conduit for underwater pool light/switch BrandonC_1972 Electrical 1 06-25-2014 06:54 AM
Filling in our InGround Swimming Pool wnewman Landscaping & Lawn Care 17 04-22-2013 08:27 AM
In ground Pool Electric in NJ taylor01 Electrical 10 10-02-2012 07:11 PM
Electrical run to new pool house AlwayzSomethin Electrical 11 04-26-2012 02:47 PM
Cracked PVC Pool Pipe: Temporary Repair matt151617 Plumbing 7 01-17-2012 03:56 PM
