Leaking Wood Beams - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 08:02 PM   #1
sjv
leaking wood beams
my house has telephone pole sized wooden beams that are half inside and half outside the west wall of the house. below them is the basement and i am now getting leaking water into the basement after heavy wind-blown rain. i have caulked all around the suspect areas and by using a water hose outside i have found that the water seems to be coming from areas of the beams that have small hair-line cracks in the wood. is there a way and a product to seal these cracks by myself and repaint ? thanks
sjv is offline   Reply With Quote
Old 09-09-2010, 08:40 PM   #2
King Construction Inc.
use NP1 for the expansion joints, and then i would try foundation waterproofing it is super exterior rated and might be ur ticket
nking is offline   Reply With Quote
Old 09-09-2010, 09:11 PM   #3
Registered User
Rewards Points: 526
The changing seasons will expand and contract the beams making new checks to wick the water inside: http://www.sciencebuddies.org/scienc...Bio_p033.shtml
You have to remember--- it's from a tree which feeds the leaves water and nutrients-- it's made to transport liquid. Try a penetrating water-proofer outside with sunblock.
Gary
Wiring on exposed wood beams - Ontario Canada djgap Electrical 5 09-29-2010 01:41 PM
Fabricating curved wood beams for bridge abraham Carpentry 7 06-21-2010 09:22 AM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 10:00 AM
hanging weight off of tji beams?? summer76 Building & Construction 2 04-14-2009 03:00 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
