Kwikset Doorknob/Lever Removal - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-16-2015, 03:12 PM   #1
Rewards Points: 4
Hi, I'm new to posting in the forums so sorry if this is in the wrong place.
I have a Kwikset lever exterior door handle and an odd situation. The company told me it is impossible for the hex screw that holds on the handle to be lost and the handle would never stay on without it. However, it is missing and the handle is locked on. Has anyone ever had this problem before? Also, the 3/32" hex on the other side is mostly stripped, any tips on dealing with that or am I going to have to drill this?
Thanks!
ceramicmonster is offline   Reply With Quote
Old 10-16-2015, 05:44 PM   #2
Rewards Points: 18,382
Sure it was not a metric screw?
And there right without the screw in place the handle should not stay on.
Old 10-16-2015, 05:45 PM   #3
Rewards Points: 4
Right? It makes no sense and I have tried bot metric and standard. No luck.
Old 10-16-2015, 06:56 PM   #4
Oso954's Avatar
Rewards Points: 890
Do you know the model name or number of your lockset ?
On many of them, the exterior handle is part of an assembly, even if the handle happened to get drilled with the set screw hole. With this style you need to remove the interior handle and ring, and the mounting screws to remove the exterior handle assembly.
Oso954 is online now   Reply With Quote
Old 10-16-2015, 11:13 PM   #5
Rewards Points: 5,348
Post photos of the lock, inside and out.
Ron
B. Franklin 1759
Tags
door handle , security
kwikset double key deadbolt removal TarheelTerp Windows and Doors 8 01-30-2014 07:03 PM
Kwikset deadbolt removal Frustrated2012 Windows and Doors 4 09-30-2012 07:28 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
