Kohler Tank Losing Water - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-10-2019, 09:06 AM   #1
Rewards Points: 8
Hi, I have a kohler 2 piece toilet and the tank keeps losing water. I have replaced the triangle tank gasket, the fill valve, the flush valve, and the toilet seal... but it still slowly loses water. I am not seeing a leak anywhere any water or wetness, so i am assuming it is leaking into the bowl.
Does anyone have any suggestions?
Thanks,
Cliff Mc
CliffMc is offline   Reply With Quote
Old 02-10-2019, 09:11 AM   #2
Rewards Points: 528
Re: Kohler Tank Losing Water
Thanks,
Cliff Mc
get some color dye and put some in the tank, that way you can tell where the color water is , try that
del schisler is offline   Reply With Quote
Tags
plumbing , toilet
Black smelly water Gradydane Plumbing 3 11-30-2018 08:42 PM
2nd Floor Bathroom Leak KenOhio76 Plumbing 7 01-09-2018 02:10 PM
Water cuts off, why? pistol22cal Plumbing 60 04-06-2017 03:08 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
