Kitchen Hood Duct Through Window? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Msradell
  • 1 Post By Druidia
Old 05-21-2017, 05:39 PM   #1
Rewards Points: 8
Hi, I'm new to this forum, also new to home construction. A question I have when planning on improving my own home is: I want to add range hood so it vents to the outside. The cooktop is right next to the window. Can the range hood be ducted so the exhaust is through the window? Please refer to the attached image.
Apparently the cleanest solution is to hide the ducting in the cabinet above the hood, and open to the outside through wall. But I live in a coop and am pretty sure the board will not let me open a hole on the wall. so my best hope for having a natural vent hood is to open through the window. Can this be done? Are there code-related issues? What kind of window would that be?
Thanks in advance
beardaddy is offline   Reply With Quote
Old 05-21-2017, 09:15 PM   #2
Msradell's Avatar
Rewards Points: 1,012
Re: Kitchen Hood Duct Through Window?
One thing it needs to be considered is whether that window is a required escape/rescue required window. There are certain total available areas that are required in windows that are required for that purpose. Other than that, it's certainly not going to look very pretty for me outside of the building which may be another concern for your co-op board.
joecaption likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
beardaddy (05-21-2017)
Old 05-21-2017, 09:21 PM   #3
dd57chevy's Avatar
Rewards Points: 2,860
Not sure how your co-op (I had to read that 3 times , I thought you lived in a converted chicken coop ) could object to a fitted exhaust vent but would allow you to rig something through a window !
What you're proposing would wipe out cabinet space , require some kind of soffit structure & removing the upper glass .
A removable window fan might make life easier .
dd57chevy is offline   Reply With Quote
The Following User Says Thank You to dd57chevy For This Useful Post:
Old 05-21-2017, 09:22 PM   #4
ZZZZZ's Avatar
Rewards Points: 1,878
Check with your neighbors in the coop and see how they have it in their kitchens.
The window doesn't seem to be practical. What are you gong to do when it rains? or gets cold at night? Or the mosquitos start invading? etc. etc
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
The Following User Says Thank You to ZZZZZ For This Useful Post:
Old 05-21-2017, 10:03 PM   #5
Rewards Points: 8
Ah, sorry forgot the dash in-between.
a re-circ vent and window exhaust fan might be a less headache solution. I'll keep it as a close next option.
Old 05-21-2017, 10:08 PM   #6
Rewards Points: 8
This window is not escape route. Appearance would be an issue though.
Old 05-22-2017, 05:00 AM   #7
Rewards Points: 269
Is your vent going to function as a grease filter too? Or is it just for exhausting cooking smell? If it's the latter, a window fan (already mentioned previously) works very effectively and you won't need to alter anything.
I don't know how wide your window is, but window fans have two fans. On days when you want outside air coming in, you can set one fan as intake and the other as exhaust. Changing directions (intake/exhaust) is electronic (no need to physically turn the whole window fan).
dd57chevy likes this.
Druidia is offline   Reply With Quote
The Following User Says Thank You to Druidia For This Useful Post:
beardaddy (05-22-2017)
Tags
range hood , window
Kitchen Bay Window Install ddawg16 Building & Construction 5 12-21-2016 12:22 PM
Sources for kitchen garden window? Eric in NC General DIY Discussions 11 06-06-2014 09:03 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
kitchen window 7echo Remodeling 5 01-25-2009 11:15 AM
