Keep Animals Out Of Yard Drain - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree9Likes
  • 1 Post By lenaitch
  • 3 Post By AllanJ
  • 2 Post By mathmonger
  • 1 Post By chiraldude
  • 1 Post By beejoe
  • 1 Post By Bondo
Old 05-16-2019, 03:25 PM   #1
Rewards Points: 98
keep animals out of yard drain
I have 4" corrugated draining to daylight with one of these grates at the discharge..... it fits loosely into the pipe and is secured by one screw at the top.
Its kind of restrictive to flow.
Whats a better way to keep animals out of the pipe?
beejoe is offline   Reply With Quote
Old 05-16-2019, 05:06 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 940
Re: keep animals out of yard drain
My sump discharge has a piece of 1/2"-pane wire fence bent over it and secured with a stainless steel gear (hose) clamp.
beejoe likes this.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
The Following User Says Thank You to lenaitch For This Useful Post:
beejoe (05-17-2019)
Old 05-16-2019, 05:47 PM   #3
Rewards Points: 2,838
Can you find a flare endpiece that provided a wider opening of 5 or even 6 inches and you put a grate of the same kind but larger over the end?
mathmonger, lenaitch and beejoe like this.
The Following User Says Thank You to AllanJ For This Useful Post:
beejoe (05-17-2019)
Old 05-16-2019, 06:06 PM   #4
Rewards Points: 2,983
Do you just need bigger holes? Cut out every other crosspiece. What kind of animals are we talking about here?
mathmonger is online now   Reply With Quote
The Following User Says Thank You to mathmonger For This Useful Post:
beejoe (05-17-2019)
Old 05-16-2019, 08:12 PM   #5
Rewards Points: 98
The main offenders are chipmunks/ground squirels and regular sized squirels.
So smaller the better but unfortunetly the trade off is flow restriction and getting clogged by tree refuse that gets past the catch basin.
Old 05-17-2019, 10:20 AM   #6
Rewards Points: 923
Atrium drain grate. Lots of options on Amazon.
beejoe likes this.
chiraldude is offline   Reply With Quote
The Following User Says Thank You to chiraldude For This Useful Post:
beejoe (05-17-2019)
Old 05-17-2019, 10:45 AM   #7
Rewards Points: 98
I tried 1/4" hardware cloth and a hose clamp. After futzing with it for 10 minutes I got it secure but then realized the cover would have to be removed to clear tree debris from time to time.
So instead I just modified the plastic grate I already had. There was a 3" collar on the inside to attach to 3" pipe. I cut it out with a rotary cutting tool and then I drilled 1/4" holes around the circumference of the grate allowing more flow.
I attached it to the pipe with a stainless self taping screw which is easier to remove than the hose clamp/hardware cloth for clearing debris.
lenaitch likes this.
Old 05-23-2019, 02:29 PM   #8
Rewards Points: 1,040
I would work on fixing the catch basin so it traps more debris before it goes down the pipe.
Calson is offline   Reply With Quote
Old 05-23-2019, 05:54 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 194
Ayuh,..... I wouldn't worry 'bout it, 'n leave an open drainage tile,....
self-cleanin',......
Any unwanted tenants get evicted every time it rains,......
comfun1 likes this.
Bondo is online now   Reply With Quote
Do you have any advice for installing a trench drain? jmr106 Green Home Improvement 3 10-21-2017 01:18 AM
Backflow from yard drain exit back to patio steadyhand Landscaping & Lawn Care 8 08-20-2017 08:44 AM
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 12:57 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Tapping an existing 4" PVC yard drain crza1 Landscaping & Lawn Care 5 06-04-2010 03:16 PM
