Internal Concret Slab Stitching - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-18-2019, 03:40 PM   #1
Rewards Points: 18
Hi, I had an offer to fix my cracked slab for over $8000, after discount. They said it is not structural. The company wanted to drill holes and pump some poly foam under it.
I read up on it and Concrete Stitching will do the trick as well. I know how to do it, but I do not know after putting the rebar in what Polymix/Epoxy...(!?) to use to anker the rebar. Also what to use to seal the extra LOOOOONG crack. I read it has to be a ridged filler. After it is done I want to put some coat over the whole floor to level it and start putting down Vinyl Plants (lots of leaking animals ).
I been trying to figure out the best material for the money and strength.
Any help would be appreciated Thank you in advance!
wuschelsmom is offline   Reply With Quote
Old 12-19-2019, 06:35 AM   #2
Rewards Points: 18
Re: Internal Concret Slab Stitching
This is in Huntsville AL, ground is red clay, with some kind of white clay in between it.
It can get so hard that in summer the dirt cracks and it is impossible to dig with a slim spade. I was literately standing on the spade and it did not even dent the dirt.
Tags
ceacked concrete , stitching
