Indoor Doorway Flood Barrier - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 12:49 AM   #1
Rewards Points: 28
Indoor doorway flood barrier
Hi All,
I am looking to put a small 3-4 inch "step" in my laundry room doorway as there is a floor drain in there that has backed up more then once during bad storms. The bottom floor of my split level is half below ground level.
Purpose of the step would to hopefully prevent any water from making it's way out of the laundry room and into the family room. I have bought a water alarm and will also be picking up a utility pump as other preventative measures.
Now to the question - what should I build the step out of? Could a put down a piece of wood and cover it with cement? I've never done anything like this before so any suggestions would be appreciated. I'd be willing to purchase something specifically made for this purpose as well.
Thanks,
Tommy
tommy83 is offline   Reply With Quote
Old 10-18-2011, 02:14 AM   #2
Rewards Points: 6,652
You are better to put in a gate that allows water to flow out of the house, through the drain line, but will not allow water/sewage to flow in to the home. That does mean tearing up the slab, so that you can install it.
Old 10-18-2011, 06:51 AM   #3
Rewards Points: 27
It would seem like plugging the floor drain would be a better fix.
Idmason60 is offline   Reply With Quote
Old 10-18-2011, 07:45 AM   #4
How about cutting a hole in the floor to drop a sump pump in.
gseith is offline   Reply With Quote
Old 10-18-2011, 08:57 AM   #5
Rewards Points: 28
I'm not sure if the floor drain plug would work because I also have a bathroom with a shower floor drain which the water would then come out of.
I also thought about the sump pump idea... couple questions regarding that:
1) What is the smallest size pump/pit that can be installed?
2) What is the risk involved in breaking up the slab to install the pump on an old, settled house? Can it cause cracks which can spread throughout the rest of the slab?
Old 10-18-2011, 10:58 AM   #6
Cutting saw, then jack hammer.
Old 10-18-2011, 04:16 PM   #7
Rewards Points: 28
What about in regards to causing damage to the rest of the slab? Is it safe?
Old 10-18-2011, 04:48 PM   #8
Rewards Points: 5,348
If you're going to put a backflow restrictor in, do it on the main waste pipe out of the building.
Ron
B. Franklin 1759
Old paper-backed insulation = Vapour Barrier? billyh Building & Construction 3 03-15-2011 09:38 PM
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 11:16 AM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 11:12 PM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 11:58 AM
