Ice Melt Solution Instead Of Throwing Down Salt - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-18-2014, 10:04 PM   #1
From Philadelphia
Rewards Points: 291
Winter is coming and I'm looking for ice melt ideas. Does anyone know of any salt/water/brine solution that I can spray out of a pump sprayer instead of having to spread ice melt crystals/salt? Would something like this even be effective?
hellohello is offline   Reply With Quote
Old 11-18-2014, 10:31 PM   #2
Rewards Points: 996
in my experience, keeping the snow shoveled is the best way. at my house, i never use melter. when i lived in the condo, the lazzy people would stomp the snow into ice, before i (i was the only one out of several able bodied people that shoveled) got to it. i then had to use a lot of salt.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
LVDIY (11-22-2014)
Old 11-19-2014, 01:07 AM   #3
Rewards Points: 4,796
There is a video too.
http://www.harborfreight.com/propane...ter-91037.html
ron45 is offline   Reply With Quote
Old 11-19-2014, 09:39 AM   #4
landfillwizard's Avatar
Rewards Points: 618
One of the benefits of using a de-icer that is solid is the fact that once it is put down it stays in place. Liquid has the tendency to run off. When i worked for the highways department, we used a brine solution taken from gas wells to deice roadways. For a while it was cheap and we dumped it on roadways to help clear ice. If the brine didn't flow off the roadway, it worked just OK. It did melt the ice slowly but had not traction ability. after a while the price of brine got to the point that pure rock salt was purchased to gain the traction factor. If you are worked about the chlorides getting into the ground water, use urea.
landfillwizard is offline   Reply With Quote
Old 11-20-2014, 04:19 AM   #5
Urea...?
http://www.wisegeek.com/what-is-urea.htm
Yep...
Old 11-20-2014, 09:03 AM   #6
Rewards Points: 618
What I was referring to , is this type of urea.
http://www.ehow.com/way_5449208_use-...ow-cement.html
Old 11-21-2014, 12:03 AM   #7
landfill...
I knew you was talking about the synthetic formula.
But you know the old saying, " Don't eat no yellow snow."
By the way, hows it working out with the other site.?
Old 11-21-2014, 12:41 AM   #8
r0ckstarr's Avatar
Rewards Points: 82
Not what you're looking for, but do you have a wood stove or fireplace? Wood ashes can help melt ice.
r0ckstarr is offline   Reply With Quote
Old 11-21-2014, 08:32 AM   #9
Rewards Points: 618
Ron,
Much better. Some of the oldtimers are finding their way back!
Need lighting control solution mmccarty Electrical 9 08-25-2009 10:13 PM
Water in Basement during snow melt gruvn Building & Construction 3 05-27-2009 09:13 AM
Is this a viable solution for a water softener? imola ghost Plumbing 1 12-23-2008 11:51 PM
unconventional solution nique Plumbing 5 12-10-2006 11:34 AM
Breaker keeps being thrown (solution?) JH7800 Electrical 4 06-28-2006 04:55 PM
