How To Remove Broken Lawnmower Blade ? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree7Likes
Old 12-31-2018, 11:21 AM   #1
Rewards Points: 6
How to remove broken lawnmower blade ?
I cant get this broken blade off. The nut wont come loose at all, no matter how much pressure i apply. I have to hold the broken bit of the blade otherwise it just spins around. Is there a certain knack?
mark_castle is offline   Reply With Quote
Old 12-31-2018, 11:24 AM   #2
retired framer
Rewards Points: 62
Re: How to remove broken lawnmower blade ?
Gas or electric?
Old 12-31-2018, 11:35 AM   #3
Rewards Points: 6,770
Hi Mark, not a pro, but I would first decide if it is a left or right hand thread. Some one smarter then me should have some guidance on how to determine that.
Bud
SeniorSitizen and mark_castle like this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 12-31-2018, 11:37 AM   #4
Rewards Points: 2,222
It's removed the same way I remove pulleys that are difficult to hold. You tether a wrench ( 6 point socket or box wrench preferred ) so it doesn't fly and hit you in the crotch, then smack the wrench with a 2x4 about 3 ft. long. For reference it's called a red neck impact. If it didn't loosen you didn't smack it hard enough. Do it as if splitting fire wood.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
mark_castle (12-31-2018)
Old 12-31-2018, 11:42 AM   #5
Bud
I ain't smarter than nobody but I believe we can safely say if the discharge is right side when viewed from the rear the thread is right hand. At least that's all I've seen.
mark_castle likes this.
Old 12-31-2018, 12:15 PM   #6
Rewards Points: 6
Thank you, i will give it a go and let you know
Old 12-31-2018, 12:19 PM   #7
Depending on what broke the blade, if you plan to use the mower I suggest checking shaft run out before bothering to remove the blade. Example: If hitting a concrete boulder broke it the engine may be scrap metal.
Nealtw likes this.
Old 12-31-2018, 12:19 PM   #8
Rewards Points: 7,253
Treat it with PB or liquid wrench every day for a week. Tap it each time with a hammer taking care to not deform the nut.
Vice grips may be the only option for holding the blade bit though a piece of pipe that would slide over it would provide more leverage for holding.
Then try to remove it. Once you get it broken loose the rest is easy.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 12-31-2018, 12:22 PM   #9
retired framer
Rewards Points: 62
Don't force it just get a bigger hammer.
Old 12-31-2018, 12:29 PM   #10
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
Pneumatic or electric impact wrench.
Sent from my RCT6213W22 using Tapatalk
Mike Milam likes this.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 12-31-2018, 12:37 PM   #11
Koa
Rewards Points: 172
You didn’t say if it’s gas or electric. Is there a clutch? Impact driver and/or remove spark plug and insert a bunch of rope/cord, rotate until it bottoms out, use a pipe on the handle of your socket wrench.
Nealtw likes this.
Koa is offline   Reply With Quote
Old 12-31-2018, 02:32 PM   #12
Super Moderator
joed's Avatar
Rewards Points: 29,238
Which ever direction the blade spins when is the direction you need to turn the nut. It could be righty loosey.
Old 12-31-2018, 03:21 PM   #13
Contractor/Engineer
Rewards Points: 1,136
Pull your spark plug - just in case you get a partial revolution and it sparks and tires to start. Removing the plug means you won't have compression and you eliminate the chance of kick compressive kickback.
Domo is offline   Reply With Quote
Old 12-31-2018, 03:31 PM   #14
retired framer
Rewards Points: 62
A good fitting wrench and a good swift hit with a hammer works well most of the time.
Old 12-31-2018, 04:24 PM   #15
Rewards Points: 2,719
There is a lot of truth to that. One time I was trying to take a wheel off my truck. I got the nuts off, but the rim was just impossibly fused on there. I did the PB blaster and I was wailing on it with a 4 pound sledge hammer for an hour. The rim was getting all bent and screwed up, but it wasn't coming off. I thought a bigger hammer would just do more damage. But, I didn't know what else to try. I got 12 pound big brother and popped it off easily in about 3 whacks. No damage at all.
Nealtw likes this.
mathmonger is online now   Reply With Quote
Best Miter Saw Blade for Cabinets / Trim Scottg Tools 11 03-20-2015 09:16 PM
Lawnmower blade marks in grass asbury park Landscaping & Lawn Care 13 04-23-2012 06:50 PM
How to Remove Broken Piece from Showerhead Pipe Cindy_Home Plumbing 14 12-27-2011 04:36 PM
Remove A Broken Light Bulb Floyd Chandler Electrical 0 08-14-2011 03:50 AM
How do I remove a piece of broken PVC? Geoffro Plumbing 3 04-21-2007 09:59 AM
