How Long Does The Wood Last? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree13Likes
  • 3 Post By chandler48
  • 1 Post By ClarenceBauer
  • 2 Post By Bondo
  • 1 Post By Gregsoldtruck79
  • 2 Post By Guap0_
  • 3 Post By lenaitch
Old 06-26-2018, 06:19 PM   #1
Rewards Points: 82
how long does the wood last?
Hello! How long can you expect all the wood in your house to last if its kept dry and maintained? From the floor joists, to the internal wall frames, to the plywood underfloor.
tambourinecactu is offline   Reply With Quote
Old 06-26-2018, 06:23 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 958
Re: how long does the wood last?
Is this just a warm and fuzzy question or do you have concerns that need to be addressed? Houses last for 100 years, some for 50. I have worked on buildings that were built when George Washington was President in 1793. Really subjective to the type of wood used and the manner in which it was installed, flashed, covered and kept from the elements, including water, sun, wind and ice/snow.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 06-26-2018, 06:30 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 240
I grew up in a home built in 1846. I drove past it a few years ago, and it looked the very same.... it does have a historical plack for its age, but it is not an expensive home, and I presume it's maintenence has just been just normal and responsible maintenance.
I'll bet some historical properties are probably over 300 years old in America... and well beyond that in Europe...
Just guessing
MTN REMODEL LLC is offline   Reply With Quote
Old 06-26-2018, 06:40 PM   #4
Rewards Points: 118
I have worked on structures that date to 1701 , 1803 thru 1890 all have good wood still remaining the 1701 structure has wood so hard you cannot cut it with a wood saw blade.
tambourinecactu likes this.
ClarenceBauer is offline   Reply With Quote
Old 06-26-2018, 06:46 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,782
Ayuh,..... Can't say for Sure, as that day ain't come yet,......
Wood, kept dry, will virtually last forever,....
dd57chevy and tambourinecactu like this.
Bondo is online now   Reply With Quote
Old 06-26-2018, 06:52 PM   #6
Rewards Points: 22
Yea, but you guys are talking about back when they had REAL trees. Back when big old 75 - 150 year old trees were harvested to build with. Most times the trees were harvested right on the properties of the home, being built.
For the passed 60 years now, our homes have been built from "whimpy" trees.
Those little sprigs they "re-forested" with, right after the lumber jacks flattened a whole side of a mountain's forest and shipped the logs out. And soon as these sprigs get legal cutting size, they cut them down and ship to the big box stores and stamp them grade one lumber. . Whimpy boards they are.
Gregsoldtruck79 is offline   Reply With Quote
Old 06-26-2018, 06:55 PM   #7
Guapo
Rewards Points: 11,950
Is this just a warm and fuzzy question.....?
LOL
Didn't he have wooden teeth that lasted for a long time? That's what I heard.
Guap0_ is offline   Reply With Quote
Old 06-26-2018, 06:55 PM   #8
Rewards Points: 82
definitely warm and fuzzy, getting ready to do a house build and am just trying to soak up as much knowledge as possible
Old 06-26-2018, 06:56 PM   #9
Rewards Points: 82
wow! any pictures?
Old 06-26-2018, 08:46 PM   #10
Usually Confused
lenaitch's Avatar
Rewards Points: 238
I just got back from a vacation in Nova Scotia. There is a house in the town I was visiting (oldest settlement in Canada) that was built in 1603 and, as far as anyone knows, has been continuously occupied. One of the floor boards is 23" wide. My last house was build around 1895 and, of course, Europe has buildings much older. Dry and bug-free and wooden structure should last for just about ever.
_________________________________________
Sic Itur at Astra
lenaitch is offline   Reply With Quote
Old 06-26-2018, 10:18 PM   #11
Rewards Points: 118
You are 100% correct the lumber was harvested from the local forest most if not all is Heart Pine and some were so hard we needed to use self drilling screws for attachment. A lot of the older churches had wood pegs holding the units together. One church I remember had a very large timber beam that was locked together by a very neat cut joint ( kind of a zig cut ) with a very large wedge drive in to lock the beam together making one long beam.
Have only seen that splice one time.
How long to acclimatize engineered wood flooring? Photobug Flooring 4 10-25-2017 06:17 PM
After applying wood filler, how long can I wait to sand? Rav Painting 5 07-30-2012 10:45 AM
How long can I store pressure-treated wood before using? DaveNJ Building & Construction 6 11-11-2009 08:39 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
