How To Fix Drywall? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By billkater
  • 3 Post By chandler48
  • 1 Post By VAer
Old 03-23-2018, 07:40 AM   #1
VAer's Avatar
Rewards Points: 1,632
How to fix drywall?
Contractor cuts the hole too big. The wall plate cannot cover the whole hole.
For four gang plate, it is behind the receiver, that is a little acceptable. But others(only two one gang banana plates) look bad.
How to fix drywall?-img_20180323_073242.jpg   How to fix drywall?-img_20180323_073259.jpg
VAer is offline   Reply With Quote
Old 03-23-2018, 08:29 AM   #2
retired painter
Rewards Points: 816
Re: How to fix drywall?
Remove the plate and flat tape/finish the edge. Or you could neatly caulk the gap although that might need to be redone if the plate is removed later.
mark sr is online now   Reply With Quote
Old 03-23-2018, 08:43 AM   #3
Guapo
Rewards Points: 11,950
A Goof plate will cover the second hole. They are made for that problem. Home Depot has them.
Guap0_ is offline   Reply With Quote
Old 03-23-2018, 08:47 AM   #4
VAer's Avatar
Thanks, I think I will go with caulk then
Old 03-24-2018, 08:30 PM   #5
Rewards Points: 50
Over sized plates. Last alot longer than caulk and look better
Sent from my SM-G920V using Tapatalk
Guap0_ likes this.
billkater is offline   Reply With Quote
Old 03-25-2018, 05:54 AM   #6
retired painter
Rewards Points: 816
Can you get an oversized plate for the communication box?
Old 03-25-2018, 12:52 PM   #7
Rewards Points: 248
The rectangle with those ports may come apart from the main plate. Take the over size plate and reassemble with j weld or such. When at the store, note the sizes and what they're called. There is another name for bigger plates which I can't remember.
Also, remove the plate and look at what's behind. I think those ports don't have a metal box, just some kind of anchor and maybe you can reposition it.
carpdad is offline   Reply With Quote
Old 03-25-2018, 12:56 PM   #8
VAer's Avatar
For four gang theater plate: it is very difficult to find four gang theater plate, it is already lucky to have found one.
For one gang banana plate: I have ordered it from Monoprice, and they are small too. I tried to search on Amazon for bigger plate, there is almost no difference. I have also been to home depot. I don't found big banana plate.
Old 03-25-2018, 12:59 PM   #9
Naildriver
chandler48's Avatar
Rewards Points: 958
Remove the plates, repair the edges and reinstall the plates, straight this time. I would not order new plates.
Gymschu, mark sr and cee3peeoh like this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 03-25-2018, 01:02 PM   #10
VAer's Avatar
I would go with caulk, make it easy for myself. Currently, drywall is not urgent, I need to fix HDMI cable and speaker wire.
chandler48 likes this.
Old 03-25-2018, 09:15 PM   #11
Rewards Points: 1,826
For the small one, those connectors can be removed and installed in a plain plate that you can get at the home center. Drill holes the right diameter for the connectors. Generally, plates come in three sizes, small, regular and oversize.
For the big one, the best option I see is a bit of mud or plaster and paint. Caulk will look messy.
ChuckF. is offline   Reply With Quote
Old 03-25-2018, 10:24 PM   #12
Conservitum Americum
cee3peeoh's Avatar
Rewards Points: 76
Small?
cee3peeoh is offline   Reply With Quote
Old 03-28-2018, 11:31 AM   #13
Rewards Points: 12
Mono price is where I usually look.
stxalumni is offline   Reply With Quote
Old 03-30-2018, 03:41 PM   #14
Rewards Points: 36
i had the same problem, nice thread
blackone is offline   Reply With Quote
Sagging Joists & Strongback Question PSUlion01 Building & Construction 29 08-09-2015 03:12 PM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 09:42 AM
Drywall Dust Question izzyant88 Drywall & Plaster 1 10-28-2011 09:15 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
