How To Clamp A Door? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By mathmonger
Old 09-15-2016, 09:51 PM   #1
Rewards Points: 2,965
How to Clamp a Door?
I have to shave down a door. I have a hand plane to shave it, but it would have to be clamped really well. Pretty sure it has to come off the hinges so I have room to plane the bottom. How can I hold it in place?
mathmonger is online now   Reply With Quote
Old 09-15-2016, 10:54 PM   #2
JUSTA MEMBER
Rewards Points: 1,470
Re: How to Clamp a Door?
What do you have to clamp it?
A few pipe clamps on the opposite side, running both ways from the door, would hold it.
A Workmate would hold it, Some hand screw clamps , one on each end.
What you got?
ED
de-nagorg is offline   Reply With Quote
Old 09-15-2016, 11:08 PM   #3
I have some various c-clamps and bar clamps. I guess I just don't know what to clamp it to that would be heavy enough.
Old 09-15-2016, 11:33 PM   #4
JUSTA MEMBER
The step-bumper on your pick-up?
A heavy piece of equipment, look around your work space.
ED
Old 09-16-2016, 12:26 AM   #5
Rewards Points: 3,536
It's time to purchase at least 2 Quick Grip clamps.
Lay the door on a side edge down with the bottom end extended out into a door opening, elevate it to a comfortable working height for planing and clamp it to the casing/trim. i.e. clamp it to a wall. I would use some of my rubber shelf liner on jobs like that.
Old 09-16-2016, 12:59 PM   #6
Clamped it right on the edge of the trim. I knocked the clamps off a few times, but I made it work. Thanks.
oh'mike and de-nagorg like this.
The Following User Says Thank You to mathmonger For This Useful Post:
SeniorSitizen (09-16-2016)
Old 09-22-2016, 05:35 AM   #7
Rewards Points: 2
its not a very difficult task but this a technical work.i had clamped my door in a striking way.
sk194871 is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 08:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 10:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
