How To Best Cover Weep Holes On A Brick Wall - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2008, 10:27 PM   #16
Rewards Points: 1,232
That is fine, so what you will want to do is use a small screwdriver to stuff the wool into the joint. Once it is fullish, use snips to cut it off flush, then ram it in some more.
Tscarborough is offline   Reply With Quote
Old 06-10-2008, 10:29 PM   #17
K&B Remodeler/Tile Guy
angus242's Avatar
Well I don't know why you say rope would equate to a mortar-like situation. You should know that it's a common practice to use rope in weep holes when laying the brick. I mean the rope alone should suffice in keeps "things" out.....not even needing citrus.
Are you suggesting that trying to add rope after the fact is a bad idea?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-10-2008, 10:50 PM   #18
Yes I am. Aside from the silliness of trying to get a limp noodle into a frictious slot, the usefulness of cotton rope is on the inside of the airspace, not in the brick joint or outside the face.
Ants like cotton and will destroy it in short order, and over time unless you maintain the citrus oil.
Citrus oil infused cotton rope is hydrophobic, and will act as a moisture/water vapor plug.
Old 06-10-2008, 11:08 PM   #19
angus242's Avatar
Thank you for clarifying that.
Angus
My Albums
Old 10-11-2011, 10:34 PM   #20
Steel wool does not work
Don't do it, this guy doesn't know what he's talking about! A year ago, I followed the advice of sticking very fine steel wool in the 100 or so weep holes around my house. This did nothing to keep the ants out no matter how hard I jammed it in with a screw driver, they would simply find a crack or small crawl space in the mortar that the steel wool did not completely seal. If I managed to seal one, they would move on to the next weep hole and do the same thing. After a month or two I gave up. Of course I was bound and determined not to use pesticides. I'm now considering sealing the weep holes. They are more trouble than they are worth, especially given that my house is overly dry all the time any way, due to A/C and heater sucking moisture out. I certainly don't plan on paying $200 for those tiny little "bug out" covers that look like a small fire ant could crawl through. Weep holes are great if you live in an overly moist area, for the other 95% who don't, they are a headache. My house gets more than it's fare share of sunlight here in Houston, and the temperature anywhere inside my walls during a summer day is 90-100 degrees F. Now if I had the chance of standing water near my house or a lot of shade, sealing them wouldn't be an option. Of course, common sense doesn't factor into building codes.
badAdvice is offline   Reply With Quote
Old 10-11-2011, 10:45 PM   #21
concrete contractor
I found this whole thread entertaining. Sort of like a 'Who's on First'. Take the show on the road boys.
johnnyconcrete is offline   Reply With Quote
Old 10-12-2011, 06:41 AM   #22
PoleCat's Avatar
Rewards Points: 1,652
What is so bad about pesticides? Only bunny humping tree huggers are gullible enough to believe they are pure evil. There is no practical way to mechanically seal out insects in the first place so the proper application of an insecticide barrier will send them elsewhere.
PoleCat is offline   Reply With Quote
Old 10-12-2011, 11:51 AM   #23
43 years in construction
Arkitexas's Avatar
Rewards Points: 77
1. It's impossible to seal all the tiny holes that an entire army of ants is spending 24/7/52 to find. If they can't get in at the weeps, they will find a path at a door, window, dryer vent, light fixture, soffit, eave, telephone line, hose faucet, gas line, fascia, vent, etc. There are so many 1/16" diameter entry points in a home that you can't humanly find them all.
2. The weeps are in masonry walls to provide moisture an escape path from the wall cavity. They should not be sealed up. Rope weeps are notoriously ineffective in transferring moisture. If you soak the rope in citronella (a hydrophobic substance) the water absolutely cannot soak along the rope and you will have permanently sealed the weep. Besides not sealing every hole in the house, steel wool will rust and leave stains.
3. Your choices are really limited to using some form of pesticide. I recommend Amdro-AntBlock sprinkled lightly around the house perimeter. It will kill many species of both worker and queen ants. It is non toxic to humans and pets. If you are adverse to pesticides, then you need to get used to the idea of ant roommates.
Rick
Arkitexas is offline   Reply With Quote
Old 10-12-2011, 03:39 PM   #24
Concrete & Masonry
Rewards Points: 384
Well, at least you chose a fitting screen name. Unless brick are less porous and it never rains in Houston, you really are giving bad advice.
jomama45 is online now   Reply With Quote
Old 10-12-2011, 03:42 PM   #25
Concrete & Masonry
Rewards Points: 384
Good post overall, but if you reread, you'll see Tscar recommended using stainless steel wool.
As for rope weeps, they're no longer allowed per code here in WI, as it's just as important to allow air in as it is to allow moisture out of the holes.
Old 10-12-2011, 06:03 PM   #26
concretemasonry's Avatar
Rewards Points: 2,716
jomama45 hit the nail on the head, especially about letting the air out at the top under an overhang at the top (often called vents) that are not that common on residential buildings end up closed by later residents. - They do wonders for pressure equalization and minimizing moisture problems. You do see the vents on better residential construction.
This is even for the small "finger gap" on a cheap residential wall but are common on true cavity walls (2") that usually have rigid insulation and are laid with appropriate hardware for cavity width control.
Dick
concretemasonry is offline   Reply With Quote
Old 10-12-2011, 07:06 PM   #27
Concrete & Masonry
Rewards Points: 384
Dick,
As part of the most recent code changes here, we now have to weep at the top & bottom of walls. Typical open tube/cellular vent/"brillo" type vent under window openings & partial height walls, and the soffit needs to be held off of the wall sheating 1" when the veneer goes full wall height. I actually like the new codes, as it really should help with moisture issues you can't see, as well as effloresence problems.
Now, if they'd just outlaw adhered veneers w/o a rainscreen system built in.............
Old 10-12-2011, 10:33 PM   #28
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,826
badAdvice if you look at the date of the thread it was 2008, thought ya just might want to know.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
exposed brick wall Jrr1099 Carpentry 1 03-25-2008 02:45 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Exterior brick wall has cracks and moves...is this a huge problem? ConstantChange Building & Construction 3 06-16-2006 09:09 AM
