Help Working With HDPE / PP (cutting,drilling, Gluing, Screwing) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By XSleeper
  • 1 Post By SPS-1
Old 07-30-2020, 01:10 PM   #1
Doug Locke's Avatar
Rewards Points: 522
help working with HDPE / PP (cutting,drilling, gluing, screwing)
Im working with 1/2" thick High Density polypropylene boards to make a portable laptop desk.
I want to stick some foam on the bottom. I dont want or need expensive HDPE glue. I just need it to stick enough to not fall off (its fine/ preferable if it can be peeled off).
Will any general purpose adhesive work?
I have acrylic caulk. silicone caulk, double sided carpet tape, contact cement, liquid nails, tacky glue, super glue, liquid nails, spray adhesive, pvc cement, gorilla glue, elmers glue, self sticking velcro etc. Most of it still sealed, I rather not break seals and spending a day testing all of them if anyone already knows it wont work.
If I have to screw it on, what sort of screw/bolt should I be using?
Doug Locke is online now   Reply With Quote
Old 07-30-2020, 01:20 PM   #2
Rewards Points: 1,965
Re: help working with HDPE / PP (cutting,drilling, gluing, screwing)
I would try a latex contact cement first. Scuff the HDPE with sandpaper first.
Doug Locke likes this.
XSleeper is online now   Reply With Quote
Old 08-01-2020, 11:47 AM   #3
Doug Locke's Avatar
Rewards Points: 522
None of the glues worked well. Double sided carpet tape does stick, but if its slowly slides/deforms with uneven pressure so looks like I'm using screws.
Old 08-02-2020, 03:15 PM   #4
Rewards Points: 74
Maybe epoxy some earth magnetic to HDPE,then glue foam to thin piece of masonite with earth magnetic's
karoc524 is offline   Reply With Quote
Old 08-02-2020, 05:29 PM   #5
Rewards Points: 11,026
HDPE is going to be pretty soft, but it can probably take a screw. So then you could either screw the foam to the HDPE with fender washers, or screw a thin strip of something like wood to the HDPE, and then glue the foam to the HDPE.
If you want a stronger mechanical fastening, there are various types of threaded inserts available.
help working with HDPE / PP (cutting,drilling, gluing, screwing)-threaded-insert-2.jpg
huesmann likes this.
SPS-1 is online now   Reply With Quote
