Help Finding Wall Switch - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By KPDMinc
  • 1 Post By Nealtw
Old 06-28-2017, 04:01 PM   #1
Help finding wall switch
Does anyone make a 3 function 2 gang switch that is dimmable? I found 3 function rocker switches but non that are dimmable. This is an example of all I found http://www.homedepot.com/p/Leviton-D...-0WS/100356847
Swamp rat is offline   Reply With Quote
Old 06-28-2017, 04:38 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 1,258
Re: Help finding wall switch
I don't know how it would be configured to dim, physically. Short answer, unless someone can come up with it, no.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-28-2017, 08:19 PM   #3
retired framer
Rewards Points: 5,906
Wireless dimmer?
https://www.theverge.com/2015/8/25/9...-dimmer-switch
Old 06-29-2017, 12:57 PM   #4
Rewards Points: 312
would create too much heat for a single gang box. Ive never seen one, anyway... are you dimming 3 different lights? or what are the functions?
ChuckF. likes this.
KPDMinc is offline   Reply With Quote
Old 06-30-2017, 05:02 PM   #5
I was looking to be able to control 3 different lights and dim each from a switch similar to the one I posted
Old 06-30-2017, 07:30 PM   #6
retired framer
Add 2 more boxes.
Msradell likes this.
Old 06-30-2017, 11:03 PM   #7
Msradell's Avatar
Rewards Points: 976
I've never even seen a double switch like what you are looking for to say nothing about what was 3 of them. As mentioned earlier 1 of the major issue would be the heat build up inside of the box.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-01-2017, 11:26 AM   #8
RickMacKay's Avatar
Rewards Points: 114
I don't think you can do it.
RickMacKay is offline   Reply With Quote
Old 07-01-2017, 12:04 PM   #9
Rewards Points: 118
You might be able to do it with a few of these and that switch but you'd still have box space issue. Maybe switch the existing box to a 2 or 3 gang with a mud ring? That's a lot of extra work, and definitely not cheap though http://aeotec.com/z-wave-light-dimmer-switch
Sent from my SM-G955U using Tapatalk
zolakk is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 05:53 PM
3-way Switch Used to Bybass Dimmer Perry401 Electrical 3 05-14-2014 03:20 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
