Heavy Salt Build Up On Carpet - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By lenaitch
Old 11-25-2018, 10:16 AM   #1
Rewards Points: 24
Heavy salt build up on carpet
I left a bag of water softener salt on the carpet in my damp basement and over a period of time the salt must have have leached through the bag and now I have 1/16. - 1/8 deposit build up on carpet. And it is dried solid. Anybody suggest how to dissolve this build up deposit without ruining the carpet.
Thanks.
JackRF is offline   Reply With Quote
Old 11-25-2018, 10:37 AM   #2
retired framer
Rewards Points: 5,972
Re: Heavy salt build up on carpet
I found something for road salt.
Old 04-05-2019, 03:24 AM   #3
Rewards Points: 184
I've used salt away for a while and been really happy with the cleaning results i get with using it, i personally wouldn't use it for an out board as it can cause a clog up with residue from the solution.
jecapereca is offline   Reply With Quote
Old 04-05-2019, 10:41 PM   #4
Usually Confused
lenaitch's Avatar
Rewards Points: 940
Removing road salt from vehicle carpets is an annual Spring ritual up here. I do exactly as in Neal's post. If it's sodium chloride it should come off with just warm water.
Nik333 likes this.
_________________________________________
Sic Itur ad Astra
lenaitch is offline   Reply With Quote
Old 04-06-2019, 01:35 AM   #5
Rewards Points: 1,288
Water carves mountains.
Nik333 is online now   Reply With Quote
Old 05-23-2019, 03:06 PM   #6
Rewards Points: 2,838
I think you need to soak the carpet with lots of whatever solution you choose. Then after the few minutes you press hard and sop it up as much as you can leaving the carpet as dry as you can.
Apply lots of plain water to rinse with and again wait a few minutes and sop up as much as you can. Depending on how soiled the carpet was to start with you might need two rinses.
Then finally let it fully dry by itself.
It is hard to prove how much of the added solution you applied was sopped up but if you sopped up 50% of what you sprayed on then at least (the other) 50% of the original salt (excluding what you vacuumed off at the very beginning) will be left behind in the carpet. If you used more solution and did sop up 80% then only 20% of the solution together with (20% of) the original salt will be left behind. More soakings with solution before the still required rinses will remove more of the original salt if you had difficulty sopping up.
Old 05-23-2019, 09:25 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 960
Thread moved...
Old 05-24-2019, 09:17 AM   #8
Rewards Points: 2,150
Rent a Rug Doctor?
huesmann is offline   Reply With Quote
Old 05-24-2019, 01:27 PM   #9
In the same fashion as spraying on solution manually using a trigger spray bottle, you need to rinse the carpet when using the Rug Doctor or similar machine. Make a second trip around the room with the solution hopper in the machine filled with plain hot water.
Old 05-24-2019, 01:33 PM   #10
hissing tinnitis
Old 05-28-2019, 03:18 PM   #11
Rewards Points: 5,010
Call
Rainbow international carpet cleaning tinting and dyeing.
If in Florida call Color King.
If you have no other choice call Stanley Steamer.
ron45 is offline   Reply With Quote
Carpet in the basement Packer Backer Flooring 17 11-30-2018 03:10 AM
Can I save my carpet? drelldrell Flooring 6 06-19-2015 04:10 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 01:11 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
