Have You Seen This Hinge? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By wickethewok
  • 1 Post By BigJim
Old 04-11-2015, 01:25 AM   #1
Rewards Points: 2
Have you seen this hinge?
One of the hinges in the door of our bathroom vanity just failed and we need a replacement. The cabinet was already installed when we bought the house, so I don't know where it was purchased. It's a concealed frameless 165 degree opening hinge, stamped with part number 165A48, and I can't find it anywhere! Any suggestions on where we could find one?
It appears to be the hinge in the picture, taken from nipomebeli.com (I can't post the link), but can be found by Googling for 165A48 hinge , but they don't ship to the US.
It's very similar to a hinge from Hickory Hardware (165A45), part number p5120-14 but the fastener holes are in a different place
barclaywsu is offline   Reply With Quote
Old 04-11-2015, 06:33 AM   #2
Rewards Points: 3,130
So drill new fastener holes. They don't show, after all. Places like Lowes and Home Depot carry hinges like that; you might also look there.
Old 04-11-2015, 07:11 AM   #3
Rewards Points: 18,382
It's called a European hinge.
Old 04-11-2015, 01:26 PM   #4
Rewards Points: 2
I would drill new holes if I could, but the screws tie into a plastic insert, so there would t be enough material to hold the screws if I tried a different hole location, if that makes sense.
Old 04-11-2015, 01:31 PM   #5
PoleCat's Avatar
Rewards Points: 1,652
I have never liked those things. Too much like a Rube Goldberg device.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 04-11-2015, 10:21 PM   #6
I have a similar arrangement with the screws in my cabinets. But I've never understood the purpose of the plastic insert. Just drill the new holes and use slightly larger screws.
Old 04-11-2015, 10:52 PM   #7
funflyer's Avatar
Rewards Points: 432
Try this one...
http://www.ebay.com/itm/Hinge-165-de...item1c3899a31c
funflyer is offline   Reply With Quote
Old 04-12-2015, 09:32 AM   #8
Rewards Points: 6,236
Try Rockler or Woodcraft, or Hartville tool.
Entering your general location can help with answering a lot of times
Old 06-26-2017, 12:37 PM   #9
Rewards Points: 2
Re: Have you seen this hinge?
For anyone looking for a replacement for this hinge in the future, I used the Salice C2AFA99 hinge with B2V3H 0mm mounting plate from Salice Direct.
I know this is an obscure issue, but I spent a long time searching for a hinge with the proper boring pattern until I found one, so hopefully this helps someone in the future.
Nealtw likes this.
wickethewok is offline   Reply With Quote
Old 06-26-2017, 02:57 PM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 604
I know this is an old thread but, the plastic inserts are for ease and speed when installing the hinge. If you pull the plastic inserts out and plug the hole with a dowel you can install new screws.
jlhaslip likes this.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Repairing screen door hinge cpgoose Windows and Doors 1 07-07-2014 02:41 PM
Stuck Hinge Pin RichardZ General DIY Discussions 13 08-21-2013 02:25 PM
How to create hinge mortise on bevelled hinge edge using a router & jig? Toronto Carpentry 20 07-29-2012 11:53 AM
door hinge into a plaster wall? dbpass Remodeling 1 05-04-2011 12:49 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 08:00 PM
