Hardwood Floor Over Concrete - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 02:19 PM   #1
Hardwood floor over concrete
On DIY yesterday on HOH he said you should never put hard wood over concrete that has earth under the slab. Well that same day on house crashes he did just that. Why does DIY have shows on that tell you to do the opposite? I do like both shows. I like Holmes on Homes better. I thought about putting hardwood in my basement but realized the change in temp from the slab may cause an issue so I went with floor heat and tile like he did on that episode. It was cool that I did the same thing he did before I even seen the show.
War3 is offline   Reply With Quote
Old 10-16-2011, 05:25 PM   #2
Rewards Points: 6,652
Holmes uses different rules, when he works on homes. That is, his rules are never to go by the bare minimum code, go a couple steps over and make sure that no one has to come behind you, to correct your mistakes.
Shows like House Crashers, Bath Crashers, Yard Crashers, etc are there to sell manufacturers products. Holmes is also there to sell products, but he also has stated that he is not your typical contractor.
Old 10-16-2011, 06:04 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 1,760
Holmes does a lot of things that are allowed by code but not a good idea. Remember, codes are usually for safety. Not for longtevity of products. All contractors see things done on those home improvement shows that are not allowed in the real world.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 10-16-2011, 06:10 PM   #4
Well Holmes is the one that would not put wood over ground slab. It's house crashes that did put it over ground slab
Old 10-16-2011, 06:47 PM   #5
Rewards Points: 5,348
Many of these shows are basically, 3 Stooges with tools. They pander to imbeciles.
You need to know the difference between sound building practices and a theather of the absurd, or you'll fall into the trap of, "but I saw it on TV": why doesn't it work in my house scenario?
I'm glad you spotted the discrepancy.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
gregzoll (10-16-2011)
Old 10-16-2011, 06:58 PM   #6
There is no problem with placing wood flooring on a slab for a home on slab. It is just that you need to follow the manufacturer directions when doing so.
Old 10-16-2011, 08:22 PM   #7
remodeling pro
This is the absolute truest thing I have ever seen written here..PERIOD. Add to this the idiots who write the "Ask the Handyman" columns in the real estate section of the local newspapers.
Every DIY'er and homeowner contemplating hiring anyone shoud be required to write this post 100 times and do a 500 word essay on it.
But I saw it on ???????? show on tv, why can't you:
Totally gut and redesign my master bath, including cutting the slab to relocate fixtures, build a tiled shower stall, rewire, drywall, trim, and paint in three days.
Spend $25K on this fixer upper I bought for $20K and do a slab to roof renovation in 3 weeks, and I will make a $75K profit when I flip the house with one week on the market.
ETC, ETC
troubleseeker is offline   Reply With Quote
Old 10-17-2011, 12:03 AM   #8
Rewards Points: 1,172
Well, while we're here, let me ask. Is there anything wrong w/ wood over a slab, if we have these layers: well drained ground; compacted gravel; a good vapor barrier (like Steggo Wrap, or 10 or 15 mil poly); several inches of rigid foam; slab, w/ radiant heat. This assumes the "wood" product is OK'd for radiant heat by the manufacturer. Opinions? thanks. j
Old 10-17-2011, 12:14 AM   #9
IMO with both of those you should be fine. In my home I just did not know what was under the slab. My garage floor gets damp when i open the door with the fast temp change so I did not want to risk it.
Old 10-17-2011, 01:08 AM   #10
War: that is my thinking, too. It seems you have (virtually) eliminated the culprit w/ all that preparation, the culprit being liquid water. I know that at least one real, non-engineered wood flooring company does not recommend radiant floor heat w/ their wood. I think the engineered wood stuff is OK w/ it.
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 08:47 PM
concrete drive and walk 7echo Landscaping & Lawn Care 12 04-22-2011 05:03 PM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 03:49 PM
hardwood over concrete KarlJay Flooring 6 08-01-2010 11:56 AM
Concrete.. Better than Hardwood ? Alessandro Flooring 2 09-25-2009 08:07 PM
