Hardwood Floor Covering - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-15-2015, 01:39 PM   #1
Rewards Points: 2
hardwood floor covering
I am turning a bedroom into an art studio that may on occasion double as a guest room. The house is new construction and has engineered hardwood floors on a slab foundation. I am looking for something to protect the floor from spilled paint etc. I was told any floor covering I use should be "breathable" to allow the wood to off gas and any moisture to evaporate. I am wanting a hard surface like a roll out linoleum to use like an area rug but don't know if it fits the breathable criteria. I am open to other suggestions as well. Thanks for any recommendations.
suzepoi is offline   Reply With Quote
Old 02-15-2015, 02:58 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 7,788
Linoleum would not fall into the category of breathable.
Something that is micro perforated would qualify but I would check with the paint supply places.
The canvass drop clothes will do a good enough job of blocking the paint as long as you scoop it up fast enough.
Old 02-15-2015, 03:13 PM   #3
Rewards Points: 6,236
If you can find them the rubber backed drop or butylene are a little safer the canvas ones will let paint soak thru if spilled. However for an art studio you probably won't be dealing with very large amounts.
Entering your general location can help with answering a lot of times
The Following User Says Thank You to ToolSeeker For This Useful Post:
Windows on Wash (02-15-2015)
Old 02-15-2015, 05:20 PM   #4
Just worried about the "breathability" of those backed style ones.
Matching solid hardwood h22lude Flooring 8 11-23-2014 10:58 PM
Infested hardwood flooring (how to prevent re-infestation) diyer_12 Pest Control 4 03-18-2012 08:37 PM
3/4 Hardwood Flooring over sufficient subfloor? bout time Flooring 3 06-20-2011 06:15 AM
Lay New Hardwood On Hold Hardwood TJfive0 Flooring 3 04-30-2011 06:50 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 12:56 PM
