Hanging Wall Cabinets On Metal Studs?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By CodeMatters
  • 2 Post By CodeMatters
Old 04-20-2018, 04:15 PM   #1
Rewards Points: 860
Hanging wall cabinets on metal studs??
Can I hang wall cabinets (going all the way to the ceiling) on metal studs or should I rip the sheet down and replace with wooden studs?
Wall cabinets are going from Wall A to Wall B.
Thanks!
jaketrades is offline   Reply With Quote
Old 04-20-2018, 04:47 PM   #2
CodeMatters's Avatar
Rewards Points: 7,050
Re: Hanging wall cabinets on metal studs??
Don't know if you need to do anything, but if you do I'd suggest just
cutting "windows" and inserting plywood strips about 1/2"x3"x 15".
Mount each horizontally with 2 drywall screws.
The cupboards will cover the window so need to patch.
jaketrades likes this.
CodeMatters is online now   Reply With Quote
The Following User Says Thank You to CodeMatters For This Useful Post:
jaketrades (04-20-2018)
Old 04-20-2018, 04:48 PM   #3
Guapo
Rewards Points: 11,950
If metal studs are okay in commercial settings, I don't see why they won't be okay in residential settings. Plenty of things are hung in stores.
Guap0_ is offline   Reply With Quote
Old 04-20-2018, 04:53 PM   #4
Worked in retirement home with steel studs a few years back. Part of
drywallers contract was installation of backing for kitchen cupboards
before the drywall went on.
jlhaslip and Guap0_ like this.
Old 04-20-2018, 05:23 PM   #5
Rewards Points: 138
Depends on what guage the studs are.
ClarenceBauer is online now   Reply With Quote
Old 04-20-2018, 05:35 PM   #6
Guapo
If the backing didn't cover the entire wall, how could the drywall be hung evenly? How thick was it?
Old 04-20-2018, 05:54 PM   #7
Strips of backing (cut same length as stud center-center) running between
the studs, flush with front. This is same as I've occasionally seen done
in wood framing but not as easy to mount.
Old 04-20-2018, 06:17 PM   #8
Guapo
Thanks, since I don't do commercial work, I'll never have to deal with it.
Old 04-20-2018, 06:31 PM   #9
Rewards Points: 860
Great tip Code!
While I have your attention, I need to move 3 different circuits from Wall A to Wall B. Major appliances on that wall will be dishwasher and fridge. Then all the other crap people plug into the kitchen wall.
Any tips?
Wall B has a new dedicated 240V outlet for the wall oven.
Gas cooktop is going on the island which has electrical coming up and out of the floor.
Old 04-20-2018, 07:11 PM   #10
Anything to hide accessible JB's on wall A?
Old 04-20-2018, 07:25 PM   #11
Rewards Points: 860
Oh man I must be tired, I forgot to ask my question. Is the best way to reroute that wiring to cut the sheetrock at base moulding height and reroute from A to B? I can use my fishing rods to Fish vertically once I get to the correct horizontal location.
And Code - it didnít even think that far ahead. Yeah Iíll have to leave cover plates on the 3 existing outlets.
Iíll probably put two floor outlets on Wall A.
Old 04-21-2018, 06:54 AM   #12
Rewards Points: 860
Wall B is 2 layers of sheetrock. So Iíll look for or rip cut 1 /14Ē wood strips.
Old 04-21-2018, 07:12 AM   #13
Typos probably obvious but this should have read:
The cupboards will cover the window so NO need to patch. -DOH!
Old 04-21-2018, 07:18 AM   #14
Probably, but without being there it's hard to say.
Old 04-21-2018, 12:51 PM   #15
roofermann's Avatar
Rewards Points: 711
French cleat screwed into metal studs would also work.
roofermann is online now   Reply With Quote
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 7 06-14-2017 09:18 AM
Wall mount tv with metal studs badhaircut Building & Construction 10 07-05-2016 03:46 PM
Hanging drywall on 18 gauge metal studs Rbaker77 Building & Construction 2 07-09-2012 09:36 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
