Hang Ladder Etc From Cinder Block - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ChuckF.
Old 09-27-2016, 10:11 AM   #1
Rewards Points: 20
Question
Hang ladder etc from cinder block
Garage has cinder block walls. I want to hang a 6ft step ladder and a few misc tools (leaf blower etc)
I am afraid that if I just use tapcons into L brackets they may eventually loosen up.
Someone mentioned using either 2 2x4s or a 2x6, apply a concrete to wood type of adhesive, then use tapcons to attach the wood to the blocks while the adhesive dries. Bolt hooks into the 2x4s. This would spread the weight over multiple blocks.
Does this sound like the best plan ?
bobbee is offline   Reply With Quote
Old 09-27-2016, 11:14 AM   #2
KarenStein's Avatar
Rewards Points: 426
Re: Hang ladder etc from cinder block
Tapcons are totally unsuitable for use with cinder block. The block is simply too crumbly. Even those cheap plastic anchors work better!
If you're hanging stuff that will be held by #8 screws, the simple plastic anchors are fine.
If you're using anything larger, I'd use sleeve anchors like these:
KarenStein is offline   Reply With Quote
Old 09-27-2016, 11:18 AM   #3
Rewards Points: 3,005
Tapcons are cheap and easy, but if you just need a few of them, why don't you use some expanding anchors or lag shields?
mathmonger is offline   Reply With Quote
Old 09-27-2016, 02:11 PM   #4
Rewards Points: 20
How does this sound ?
4 bolts in each of 2 four foot 2x4s, coating the back of the 2x4s with sika construction adhesive attach to cinder block
Then use various hooks to hang a 6' step ladder and a few other misc tools.
Do you drill into the solid part of the cinder block or in the middle ?
Old 09-27-2016, 02:12 PM   #5
Rewards Points: 20
How far should the fasteners go into the cinder block
Old 09-27-2016, 07:56 PM   #6
Rewards Points: 1,900
I would run two 2x4's up to the ceiling joists and down to 4 or 5 feet high, and then attach a 2x6 eight feet long and horizontal to them, and use that board for various hooks and tool hangers.
Msradell likes this.
ChuckF. is offline   Reply With Quote
Help with a Fence to Cinder Block Wall avandelay Carpentry 7 08-30-2013 10:17 AM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 11:22 PM
Removing White Powdery Substance From Cinder Block Lawrence Coppar Concrete, Stone & Masonry 5 04-12-2012 03:28 PM
# of rebar in cinder block wall johnlvs2run Building & Construction 3 08-08-2010 11:48 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
