Gravel Walkway Subsurface - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-30-2019, 07:51 PM   #1
Rewards Points: 98
Gravel walkway subsurface
I removed a small concrete slab. I like to relevel subsurface and put crusher run or another type of gravel that would be durable.
The subsurface is sand which the slab was resting on.
Can i leave the sand?
beejoe is offline   Reply With Quote
Old 03-30-2019, 09:01 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 196
Re: Gravel walkway subsurface
Ayuh,.... Sure,..... Just throw down the crusher run, grade it to where ya want, 'n compact it,....
Bondo is online now   Reply With Quote
Old 03-30-2019, 09:13 PM   #3
Rewards Points: 98
Thx, is a sand base ok for larger clean gravel too?
Old 03-30-2019, 09:46 PM   #4
Rewards Points: 18,376
If it was mine and I did not want it to keep sinking, I'd be laying down driveway cloth, (aka silt screen) a layer of #57 stone then the crush and run.
Old 03-31-2019, 05:58 PM   #5
Rewards Points: 2,150
^^^ this.
Anytime you have layers of materials with disparate D50, you need to separate them with a geotextile to keep the finer particles from migrating into the voids, causing settlement.
huesmann is offline   Reply With Quote
Gravel Walkway Ideas Questnyc Landscaping & Lawn Care 3 07-18-2018 10:30 PM
Gravel Driveway Erosion Problem Mills314 Landscaping & Lawn Care 12 10-07-2013 10:31 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 12:12 PM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 06:52 PM
Concrete Walkway with Exposed Aggregate BTn5qsc2zB93ztGN9vJP Landscaping & Lawn Care 4 08-22-2008 08:49 AM
