Glueing Beadboard Wood, Not Panels - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-26-2017, 03:17 PM   #1
Rewards Points: 6
Glueing Beadboard wood, not panels
I just joined. Question I have is can you just use adhesive and no nails on pine T & G wood beadboard? It on vertical application over drywall. These are at best 4 1/2 foot tall and most are under cabinets in kitchen.
Additionally has anyone used the Ever True planks from lowes? They are PVC material and I believe that you only use adhesive.
Thanks, I need suggestions and advice.
Grumpy23 is offline   Reply With Quote
Old 04-26-2017, 03:49 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 29,536
Re: Glueing Beadboard wood, not panels
Gluing to the drywall will mean the dry will need replacing if you ever try to remove the beadboard.
Old 04-30-2017, 01:47 PM   #3
Professional
Rewards Points: 188
If you you are going to hit studs through the drywall you can get away with no glue. If you are just going to tack the pine to the drywall then you should use some glue. As far as repairing drywall if you decide to remove it later, either way there would need to be drywall repair.
I like 2" 18g nails blind nailed for t n g.
Str8AheadInc is offline   Reply With Quote
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 03:07 PM
Suspended wood ceiling panels (basement) High Gear Building & Construction 4 12-30-2009 11:06 PM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 05:30 AM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
