Gas Stove Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 10:53 PM   #1
Gas stove question
I recently bought a house which has a propane tank which is plumbed throughout the house and deck. I purchased a gas fireplace and put out on the deck. However, I cannot get it to light. I know that air is coming out of the line, however the pilot light is not lighting. Do I need to purge the gas line? This is the first time out has been used by us. I checked all the connections and there are know leaks. When I put a lighter to the pilot and turn the gas on, the flame moves (so I know air is coming out) however it is not flammable.
Bahuffma is offline   Reply With Quote
Old 08-28-2011, 04:39 AM   #2
Rewards Points: 994
When you see the flame moving, you are purging the gas line. Sometimes, I wll turn on a range burner and hold the match near the burner. More gas flows through the range burner than the pilot. Try the pilot again, thistime with more patience
fireguy is offline   Reply With Quote
Old 08-28-2011, 08:48 AM   #3
Rewards Points: 6,652
Here is a really big question. Did you put in the orifice for Propane on your "gas" fireplace? As for that air, it is not air, it is vapor that you are releasing into the atmosphere.
Moving heat from wood stove in basement Mike in MN HVAC 0 11-23-2010 12:04 PM
Parlor Stove Retrofit?? Master Brian HVAC 6 11-20-2010 02:19 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood Stove Question econdave HVAC 6 11-15-2006 07:11 AM
Tricky Wood Stove Question Mosca General DIY Discussions 7 12-22-2005 01:42 AM
