Gas Furnacce - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-02-2013, 10:35 AM   #1
Question
Gas Furnacce
There is a 25 year old gas furnace in the house we rent. (The guy that owns the place claims there is NO problem at all. He said the igniter is brand new and working fine.)
It blows cold air for the first 10 minutes of each heating cycle.Then heat starts to appear fine.
I have had the furnace checked and the guy said it was fine ... that it was normal ...has new filter and new thermostat ... please can anyone help
englandmod is offline   Reply With Quote
Old 12-02-2013, 11:28 AM   #2
Rewards Points: 6,236
I live in Fla. and have a heat pump that does the same thing. Feels like the a/c is on then the heat is only lukewarm. Ask me if I like heat pumps.
Old 12-02-2013, 01:57 PM   #3
PoleCat's Avatar
Rewards Points: 1,652
If the fan comes on too soon after the burners light up the heat exchanger will not be hot yet. Not a big issue as the furnace will still heat the house. The duct work could also be ice cold if it is in the attic or a well ventillated crawl space and not insulated. Technically, its his furnace and it is working so lots of luck getting him to spend money on it.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
danpik (12-03-2013)
Old 12-02-2013, 08:51 PM   #4
Rewards Points: 1,002
If it has a new filter, it must be ok.
cleveman is offline   Reply With Quote
Old 12-03-2013, 07:32 AM   #5
Rewards Points: 1,332
Next time it comes on, put a thermometer in the air stream from the vents and see what the temp is. The blower comes on based on a temperature setting on a limit switch in the furnace. It may be the air stream is moving too fast and causing a draft that makes it feel chilly/colder. I would bet that the fan speed is either too high or the number of vents on the system is too few
danpik is offline   Reply With Quote
