Garbage Disposal Replacement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-03-2017, 06:43 PM   #1
Rewards Points: 189
Our Insinkerator 17 has died and I am considering replacement with a cheaper model Are the fitting locations on garbage disposals common or will I have to repipe things?
nicksteel is offline   Reply With Quote
Old 03-03-2017, 07:47 PM   #2
RRH
Rewards Points: 1,358
Re: Garbage Disposal Replacement
Yes, most are pretty standard. But cheap and easy even if you need a few adjustments.
RRH is offline   Reply With Quote
Old 03-03-2017, 07:51 PM   #3
Rewards Points: 189
Just discovered that when the switch on the photo is depressed, the unit runs, when released, stops.
Old 03-06-2017, 05:21 PM   #4
Rewards Points: 189
Insinkerator said there were no parts available and that I should buy a new one. As the thing runs just fine with the switch in the photo held down with a rubber band, we're just using like an ordinary one and controlling with the wall switch.
New Garbage Disposal Not Working akim1220 Plumbing 13 04-20-2015 09:18 PM
Garbage Disposal Wiring Charlie15 Electrical 1 12-29-2014 11:30 PM
Garbage Disposal Requirements BigJimmy Plumbing 6 05-01-2014 11:05 PM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 04:40 PM
DIY Garbage Disposal replacement bigbob Plumbing 1 06-07-2006 07:05 PM
