Garage Floor Is 1 1/2 Inches Higher Thandriveway - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-29-2016, 08:04 PM   #1
Rewards Points: 82
Garage Floor is 1 1/2 inches higher thandriveway
I would like to make a ramp going into my garage making up for the garage floor which is an 1 1/2 inches higher then driveway
My truck is standard shift and I feel a ramp would make it easier to get in to the garage
Maybe use a 2x12 and cut it on an angle or use a 1x12 put wedges underneath then fasten to concrete with tapcons or lead anchors
I don't think concrete will work
mga123 is offline   Reply With Quote
Old 04-30-2016, 01:02 AM   #2
Rewards Points: 1,036
Re: Garage Floor is 1 1/2 inches higher thandriveway
you could get one of these pipe and hose ramps and cut it in half lengthwise.
http://rubberform.com/products/road-...ipe-hose-ramp/
Mingledtrash is offline   Reply With Quote
Old 04-30-2016, 04:28 AM   #3
Rewards Points: 82
I didn't know about that website I wonder if it's expensive I will have to look into it!!
Old 04-30-2016, 05:22 AM   #4
JUSTA MEMBER
Rewards Points: 3,342
Around here people just get a 1/4 inch thick steel plate from a recycle center, have it cut to length, and as wide as 4 feet, to ease the angle.
Lay it in the doorway with it on top the garage floor, and anchor bolted at the corners.
ED
de-nagorg is online now   Reply With Quote
Old 04-30-2016, 07:11 AM   #5
craig11152's Avatar
Rewards Points: 1,220
Seems like a few options but if you get 3/4" like a 1x or a strip of 3/4 pressure treated ply then instead of a 1.5 inch bump you have 2 separate .75 bumps. That should be plenty.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 04-30-2016, 09:22 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,062
Ayuh,.... Good idea,....
Or bevel one edge of a 5/4 deck board,....
Old 04-30-2016, 03:22 PM   #7
Licensed Engineer
Rewards Points: 509
Why not fix the cause of the problem and 'mud-jack' the driveway?
MI-Roger is offline   Reply With Quote
In theory: expand attached garage, or add detached garage? hyunelan2 Building & Construction 5 11-09-2012 05:34 PM
Retaining wall for driveway and garage dalepres Building & Construction 6 03-21-2011 09:03 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
