Garage Ceiling Repair? How To Fireproof? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-01-2016, 03:31 PM   #1
Rewards Points: 2
Garage Ceiling Repair? How to fireproof?
I've had water damage...tub leaked down through garage ceiling, destroying drywall on the bottom of a chase holding ductwork etc. It was previously insulated and drywalled, with a popcorn finish.
Can I replace just the bottom of this "dropped down" area...think it's called a chase....with some kind of fire-rated plywood and insulation instead of drywall? If so, how would I make it up to code?
Thanks!
pjbogden is offline   Reply With Quote
Old 03-01-2016, 05:19 PM   #2
Rewards Points: 18,118
Has the leak been fixed?
No such thing as fire proof plywood and not even sure why you would want to use it instead of 5/8 drywall.
Old 03-01-2016, 10:21 PM   #3
Rewards Points: 1,830
Why do you want plywood vs drywall? Is it because you want something more water-resistant?
Consider that if there was something more water-resistant than drywall there, the water may have built up to the point where greater damage was done. Consider also that plywood is more difficult to finish than drywall.
ChuckF. is offline   Reply With Quote
Old 03-02-2016, 07:29 AM   #4
Rewards Points: 6,236
Just use fire rated drywall.
Entering your general location can help with answering a lot of times
Higher ceiling in garage plus master bedroom above marinegrunt Building & Construction 4 11-01-2015 01:21 AM
Garage ceiling foam insulation question richlux Insulation 6 10-16-2015 05:26 PM
Garage ceiling joist, bracing, and insulation ACR_SCOUT Building & Construction 11 01-21-2013 07:05 PM
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 09:05 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
