Gap Between Skylight And Drywall - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 09-22-2018, 10:52 PM   #1
Rewards Points: 92
Gap between skylight and drywall
Hi
We had new skylights installed along with a new roof. What should I do to cover the gap between the drywall and skylight base?
007noob is offline   Reply With Quote
Old 09-22-2018, 11:35 PM   #2
Rewards Points: 4,270
Re: Gap between skylight and drywall
Hard to tell how wide it is from here but you could caulk it, cover it with some kind of molding or fill it with drywall and/or joint compound.
stick\shift is online now   Reply With Quote
Old 09-23-2018, 08:01 AM   #3
Rewards Points: 92
The largest gap is about 1/2 inch.
Hereís a few close ups of all 4 corners of one of the skylights.
Old 09-23-2018, 08:31 AM   #4
retired painter
Rewards Points: 626
Many of the skylight holes I've painted had a piece of baseboard [turned upside down] to hide that gap.
Hidyi likes this.
mark sr is offline   Reply With Quote
Old 09-23-2018, 08:35 AM   #5
Rewards Points: 7,261
Mine are trimmed in with (I forget the real name) what looks like the top 1.5" of a standard baseboard installed upside down.
Starter strip?
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 09-23-2018, 08:37 AM   #6
Rewards Points: 92
So if I were to use molding do I nail it in the drywall? It seems a bit brittle especially near the edge. I donít see any wood hiding behind the drywall to nail into.
Old 09-23-2018, 08:41 AM   #7
There has to be wood on the sides (the rafters), but it may not go all the way up. Using the full 3.25" BB would allow to hit wood somewhere in the height of the board.
Your top and bottom drywall must be nailed or screwed to something. Probe with a pin or call the contractor and ask where the wood is.
Colbyt
Old 09-23-2018, 08:57 AM   #8
retired painter
Rewards Points: 626
Starter strip?
You probably mean base cap.
Old 09-23-2018, 09:27 AM   #9
Rewards Points: 172
Also the plastic trims, whatever that'll work. Drywall uses a U trim or maybe called J trim to cover a cut edge. You can cut off one of the edge and glue it. DAP painter's caulk will work as glue although maybe additional dabs of quick drying caulk or glue to hold position. Panelling section of the hardware may have angle trims. You don't have to use the finish side of the trim as long as it looks finished.
carpdad is offline   Reply With Quote
Old 09-23-2018, 09:48 AM   #10
No. But that would certainly work.
In trying to find what I meant I decided for a limited skill and tool set that a simple lattice molding might be the better choice as miter cuts not required.
What I mentioned originally was what was used in the parts as a starter strip nailed to the wall for the installation of crown mold in some of the high end homes.
Colbyt
Old 09-23-2018, 09:54 AM   #11
Rewards Points: 92
Would this work?
Old 09-23-2018, 12:39 PM   #12
retired painter
Rewards Points: 626
Those squeeze tubes of caulk work ok for some but I've always found them hard to control [too messy]
Old 09-25-2018, 03:21 PM   #13
Rewards Points: 172
Yes and almost any caulk will work since caulk is an adhesive at the same time. Not silicon in case of a smear and you can't paint over silicon. If using wood trim, may want to drive a couple of brads even into the drywall to hold the position. If using plastic, you could even cut slits into the section so you can follow the frame curves, if the frame is uneven.
Old 09-26-2018, 12:34 AM   #14
Rewards Points: 16
White plastic molding won't be affected by moisture ... and would stay relatively white, and not yellow in the bright light
geno03245 is offline   Reply With Quote
Interior of skylight - drywall or mdf Schuler1965 Windows and Doors 6 01-15-2018 06:09 PM
Should vapor barrier be used inside skylight boxes prior to drywall AidaCarrell Building & Construction 3 04-26-2016 05:29 PM
Help with drywall after removing skylight diystephen Drywall & Plaster 4 08-12-2014 02:04 PM
Reparing/Finishing drywall under skylight..help!! greymoose Drywall & Plaster 4 11-25-2013 11:34 AM
drywall on skylight shaft walls above ceiling amakarevic Drywall & Plaster 5 03-25-2012 11:53 AM
