Gap Between The Baseboard - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2015, 01:39 PM   #1
Rewards Points: 89
Gap between the baseboard
How do I get rid of the gap between the baseboard & the wall?
Gap between the baseboard-20150613_123113.jpg   Gap between the baseboard-20150613_123108.jpg
Fly_on_the_wall is offline   Reply With Quote
Old 06-13-2015, 03:24 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 8,532
Caulking.
Old 06-13-2015, 07:35 PM   #3
Rewards Points: 89
Sounds simple enough. Thanks.
Old 06-13-2015, 08:28 PM   #4
Rewards Points: 6,652
You can tell that there was caulk there before, but appears that over time it has shrunk, or the baseboard has.
Old 06-14-2015, 10:53 AM   #5
Rewards Points: 89
So should I just recaulk it anyways?
Old 06-14-2015, 03:53 PM   #6
Rewards Points: 6,236
Yes but a gap that small don't cut the end of the tube any bigger than you can help. If you cut it too big it makes a mess. And don't use silicone.
Entering your general location can help with answering a lot of times
Old 06-15-2015, 12:33 AM   #7
Rewards Points: 5,012
It doesn't look like baseboard to me.?
ron45 is offline   Reply With Quote
Old 06-26-2015, 12:21 PM   #8
Rewards Points: 89
What's wrong with using silicone?
Old 06-26-2015, 12:33 PM   #9
Nothing. It flexes better than acrylic. But some will not take paint very well.
Old 06-26-2015, 01:23 PM   #10
ZTMAN's Avatar
Rewards Points: 492
And as a practice, I remove the old caulk with a utility knife. If you just go over the cracked caulk, its not going to look good
ZTMAN is offline   Reply With Quote
Old 06-26-2015, 01:39 PM   #11
funfool's Avatar
Rewards Points: 534
still not understanding the photos and where the actual gap is, is it two piece base or is the gap between the base and the floor?
I dunno just wondering.
funfool is offline   Reply With Quote
Old 06-26-2015, 01:41 PM   #12
Rewards Points: 89
The gap is between the top of the baseboard and the wall.
Old 06-26-2015, 03:59 PM   #13
Rewards Points: 3,130
What you want is called painter's caulk. Inexpensive, and designed to be painted.
Old 06-26-2015, 05:04 PM   #14
Rewards Points: 117
Try Dynaflex 230.
tommyxv is offline   Reply With Quote
Baseboard. A Big Deal Question! altc81 Flooring 15 11-03-2013 04:00 PM
Rotted Baseboard miamicuse Carpentry 11 09-08-2013 10:09 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
