Furnace Sizing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-15-2015, 01:56 PM   #1
Rewards Points: 2
furnace sizing
If I am seeing 4 burner pipes in my furnace, does this indicate it is a 40,000 BTU furnace?
tcox1959 is offline   Reply With Quote
Old 10-15-2015, 02:29 PM   #2
Rewards Points: 1,336
No, the rating plate on the furnace will give you the info you need. If you are replacing a furnace do not go by that rating as many older homes had the furnaces way oversized. The rating plate will most likely have two ratings on it. One will BTU input and the other will be BTU output. The difference between the two will allow you to calculate the efficiency rating
danpik is offline   Reply With Quote
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Help sizing new furnace..please What have I done HVAC 11 10-02-2011 05:32 PM
Sizing a furnace - can't find one small enough Jim W HVAC 30 05-13-2009 09:38 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
