FURNACE Ash - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-10-2015, 08:49 AM   #1
Rewards Points: 6
FURNACE ash
hi i have a forced hot air furnace and i have a black ash build up on the outside of my furnace and inside my furnace room i vacumed it up but its back any thoughts on whats causing it and how to fix it?
bigdew78 is offline   Reply With Quote
Old 01-10-2015, 09:03 AM   #2
Rewards Points: 107
Oil fired? Sounds like the furnace and burner need a thorough cleaning and adjustment including an evaluation of the chimney draft.
jimn01 is offline   Reply With Quote
Old 01-10-2015, 09:29 AM   #3
Rewards Points: 582
is this an older furnace with baffles on top ..Iam talking maybe 30yrs old...gas picture would help..
Old 01-10-2015, 10:08 AM   #4
Rewards Points: 6
yes it is oil fired
The Following User Says Thank You to bigdew78 For This Useful Post:
ben's plumbing (01-10-2015)
Old 01-10-2015, 10:11 AM   #5
Rewards Points: 6
yes it is an old furnace and not sure about the baffles
Old 01-10-2015, 10:22 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 116
You should get it properly serviced by a licensed oil tech. He should use a combustion analyzer to set it properly. If it is not burning cleanly and producing black soot then that lowers it's efficiency drastically and increases your oil consumption and $$ cost dramatically. He can see where the soot is coming from at that time. The chimney may need cleaning and inspecting also. Oil like gas can produce CO Carbon monoxide so you don't want that in your house either.
The Following 2 Users Say Thank You to yuri For This Useful Post:
ben's plumbing (01-10-2015), gassyplumber (01-10-2015)
trouble wiring furnace with single zone relay for circulator btomassacci HVAC 4 12-05-2014 07:08 AM
Is this a furnace problem? joannie HVAC 31 11-16-2014 09:00 PM
Connect AC to Central Air Furnace MaxOvrdrv HVAC 42 05-16-2014 09:50 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
