Frozen Kitchen Sink Water Line - General DIY Discussions - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ZTMAN
Old 01-07-2017, 11:29 AM   #1
Rewards Points: 378
Frozen Kitchen sink Water line
Ok so here in Dallas, TX it got down to 16* and I am the lucky butthead that has a frozen water line.
My kitchen sink has no hot or cold water, nothing comes out, but everything else is fine. 2 bathrooms, showers, toilets, fine, hot and cold no problem.
My hot water heater is in the garage (un-insulated).
I am curious to know how can I find the frozen section? Or do I have to wait it out until it thaws?
I had a small portable heater under the sink for hours, didn't seems to help.
I took pics of the copper flex pipe off my water tank that seems to be cold.
Also 2 pics of my the attic, not sure what to do.
Any thoughts.
Thanks.
Frozen Kitchen sink Water line-img_1263.jpg   Frozen Kitchen sink Water line-img_1266.jpg   Frozen Kitchen sink Water line-img_1267.jpg
Alumifab is offline   Reply With Quote
Old 01-07-2017, 12:35 PM   #2
Rewards Points: 3,700
Re: Frozen Kitchen sink Water line
Just a wag but the cold water line that feeds the water heater for hot and cold water to that kitchen sink is in an outer wall and the water pipe is on the wrong side of the insulation. A typical builder / contractor error when insulation isn't understood. Wait until it thaws and hope it doesn't leak.
During the next extreme cold in your area leave the cold water tap running over night with a stream about the size of the lead in a pencil. During awake hours and the sink is being used occasionally that little stream isn't necessary. This worked at my house last night with a over night low of 3F. and has always worked for me.
Old 01-07-2017, 01:46 PM   #3
ZTMAN's Avatar
Rewards Points: 492
Based on your description, the lines to the kitchen are frozen so you have isolated the section of pipe. Look for areas where the lines go through openings and apply a small amount of heat. A hair dryer works good, or even a 100w light bulb.
I would leave your kitchen tap open, and start warming the lines. I would also let the water run in other areas of the home. It will eventually thaw, and hopefully its not frozen hard because that could crack the pipe.
Get all hands on deck. Give any one in the home something to heat the lines from the kitchen faucet back to the connection where their is flow
ZTMAN is offline   Reply With Quote
Old 01-07-2017, 01:51 PM   #4
Rewards Points: 378
I have a portable heater under the sink, those lines are warm/hot.
I just can't reach the line from the water heater to the sink as I think it runs along the outside bricks and it's frozen.
My washer doesn't have any water either.
You said to continuously run the water in another bathroom.
Does it matter, hot or cold?
I have both taps open in the kitchen sink.
Others in my neighborhood have no water to the washer, but everyone's sink (but one (hot line only frozen) seems to be fine or they aren't saying anything on social media.
Old 01-07-2017, 01:56 PM   #5
ZTMAN's Avatar
Rewards Points: 492
Run your shower with hot and cold
ZZZZZ likes this.
Old 01-07-2017, 03:16 PM   #6
Rewards Points: 378
Well the kitchen came back on, hot and cold. Don't see any leaks yet..... Hope there aren't any, but walking around the house I see this.....
Real life issues.....
Old 01-07-2017, 04:07 PM   #7
ZTMAN's Avatar
Rewards Points: 492
You can deal with that. Hard to tell from the pic, but was that a leak that froze or did it crack the silcock.
Regarding the interior, if its going to freeze tonight, leave your faucets dripping as Senior suggests.
Make sure your cabinet doors are open as well so heat can get in the cabinet.
Old 01-07-2017, 04:09 PM   #8
Rewards Points: 378
Not sure......
It's not dripping right now, after I took the ice off of it, so I don't know.....
I'm afraid to turn it on, haha......
Old 01-07-2017, 04:49 PM   #9
ZTMAN's Avatar
Rewards Points: 492
If ice cracked the supply line, when it thaws you will have a mess if the pipe cracked inside the wall. If there is a shut off to that spigot, turn the water off
Old 01-07-2017, 04:51 PM   #10
Rewards Points: 378
There is no shutoff that I can find, so if I do discover a leak I will have to turn the water off from the street.
no hot water at kitchen faucet....all others are fine. ideas? tarheelblue Plumbing 10 12-29-2014 12:55 AM
Hot water clogs kitchen sink. Cold water, no clog. Nocontact Plumbing 25 10-27-2014 06:46 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Trouble with kitchen sink/hot water kid320 Plumbing 3 04-29-2010 11:31 AM
No hot water at kitchen sink allwet Plumbing 9 12-02-2009 08:37 AM
