Flooding Prevention - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2014, 08:23 AM   #1
Rewards Points: 46
Flooding prevention
Hi Guys,
Posting this here as thought better to link all the questions up in one post
We got hit with a torrential downpour last week, 3 inches in 30 minutes.
Anyway the area in blue was full of water, which got into our garage as the water could not run away fast enough due to the small holes in the
drain cover (In Red), which I could not remove at the time and still cant as the screws are rusted on tight.
I would like to increase the water run off into the drain, thinking about drilling holes into the drain cover, its made of plastic, or maybe remove and place a grill over the drain?
Also would like to put something in place to block the water getting into the garage ie. raise the plinth, maybe put a piece of wood across and
seal it?
Any suggestions on what to do will be appreciated.
Thanks for reading my post
PS I am dyslexic so if I don't get it and its really obvious, that's why
PPS Is it possible to add a signature?
JonTempleman is offline   Reply With Quote
Old 07-27-2014, 10:34 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 602
I am having this problem also, I really don't know how to correct it other than adding a small curb on the inside of the door and sealing the bottom plate so water won't come in under it. That is what I plan to do.
As for adding a signature, go to your "user CP", you will be able to add a signature there.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-05-2014, 08:37 AM   #3
Rewards Points: 46
Hi Guys, I'm bumping this as other than BigJim's, I didn't get a reply that helped me
Old 08-05-2014, 09:53 AM   #4
First Home N00b
Rewards Points: 202
Just my opinion, but you are better off attacking it from your first train of thought, increasing the drain somehow. Any attempt to block off the door is a losing fight against the water...if you do manage to build up something high enough to block water intrusion there, it will go around/under it or find another way to get into the home which is even more costly/annoying. I think you need to find a way to drain the water that is pooling in the "blue area."
Screws - a good set of metal drill bits and a drill that spins very slowly will drill the heads right off of them. Remove what is left with vice grip.
95PGTTech is offline   Reply With Quote
Old 08-05-2014, 11:14 AM   #5
Rewards Points: 2,842
Where does the drain lead to?
Given that the drain cover is plastic, drilling more holes in it is a good idea. You will have to choose hole location and size so the cover does not disintegrate.
Any way to regrade the land so not so much water accumulates in the blue area?
AllanJ is online now   Reply With Quote
Old 08-05-2014, 11:21 AM   #6
First Home N00b
Rewards Points: 202
If you are going to go the hole drilling method or modify the cover in any way, keep in mind it's there for a reason - likely to keep foreign material out. Design some sort of mesh if you are drilling especially large holes. It would be favorable to drill many small holes versus very few large holes.
Old 09-07-2014, 04:59 PM   #7
Rewards Points: 46
Hi Guys,
Drilled small holes in existing cover..
There's been no heavy downpours like the one that caused the flooding, will update if works or not
Old 10-08-2014, 08:54 AM   #8
Rewards Points: 46
Hi Guys, Had a big downpour today, usual spots in the garden flooded, the modifications to the drain cover worked a treat, no water build up at all in the path area
The Following 3 Users Say Thank You to JonTempleman For This Useful Post:
BigJim (10-08-2014), iLikeDirt (10-09-2014), Msradell (10-08-2014)
Minor Basement Flooding rjschwar Concrete, Stone & Masonry 9 05-02-2014 02:33 PM
Flooding in Wood Foundation mhp8982 Building & Construction 14 03-09-2011 02:15 PM
How do I Prevent Flooding KerryA. Building & Construction 8 11-16-2009 05:16 PM
Is having a sump pump an indication that the basement has a flooding problem? MCK Plumbing 7 08-24-2009 09:57 AM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 03:46 PM
