Fixing A Sinking Asphalt Driveway Apron - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-24-2017, 10:12 AM   #1
Rewards Points: 78
Fixing a Sinking Asphalt Driveway Apron
Hey everyone,
My current asphalt apron is about 4 inches lower than my garage slab. I know there's a few ways to rehab this, slap in a wedge or even diamond blade out a few feet of the apron and re-pour it back in .
Has anyone had this issue and what were the steps you took to resolve this? My garage and my front porch are right next to each other with a turn around (U-Shaped) driveway so I have about 25 feet wide area to fix. I'm just flipping a house so I want it to look good but don't want to spend a ton.
Thank you!
rbiankowski is offline   Reply With Quote
Old 04-24-2017, 11:11 AM   #2
Rewards Points: 4,330
Re: Fixing a Sinking Asphalt Driveway Apron
In my mind, the first step is to figure out why it's low and address that or you could be right back where you started in short order.
stick\shift is offline   Reply With Quote
Old 04-24-2017, 11:14 AM   #3
Rewards Points: 78
Well there's no adverse effects in my basement so I'm thinking it's just poor compaction underneath.
Old 04-24-2017, 12:58 PM   #4
Civil Engineer
Rewards Points: 5,246
You may be correct, and the soil underneath the apron may have improper components like organics, weak clay, tree stumps, whatever. The simplest way to fix the problem is to remove the asphalt, excavate the incompetent soil and dispose of it, replace with proper material (structural fill), compact, and repave.
Old 04-24-2017, 01:30 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,790
Ayuh,.... Call yer local Blacktop Pavers, 'n get a quote to over-lay the entire driveway,....
They'll shim up the low areas, 'n pave the whole thing,...
It'll "Look" brand new,....
The water should flow away properly too,...
Anything else ya do is gonna look like the cob job it will be,...
Bondo is online now   Reply With Quote
Tags
apron , cold mix , driveway , sinking
How to repair a cracked driveway or walkway [email protected] How To Guides 8 06-15-2015 04:59 AM
Concrete or asphalt driveway? asledge General DIY Discussions 12 04-05-2015 10:16 PM
fixing joint between Asphalt Driveway and garage (concrete) vvrishi Concrete, Stone & Masonry 4 04-07-2014 08:00 AM
Using Recycled Asphalt for Driveway? toddtx Building & Construction 2 07-17-2011 03:24 PM
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 12:50 PM
